Old 06-04-2020, 11:53 PM   #1
22rbc led bulb replacement
1st Mod
Changed out all running lights and brake lights to led and couldn't be happier. Lights are nice and bright the issues of one of my tail lights being dimmer than the other is gone.
BUCK'N PUMIE
2020 PALOMINO PUMA XLE LITE 22RC
TOW VEHICLE
GREY'S LOBOTOMY
2015 JEEP GRAND CHEROKEE LIMITED ECO DIESEL 4X4
ChuloGordo82 is offline   Reply With Quote
Old 06-05-2020, 12:52 AM   #2
Originally Posted by ChuloGordo82 View Post
1st Mod
Did you replace the bulbs or the entire housing?
GPIERCEY is offline   Reply With Quote
Old 06-06-2020, 04:16 AM   #3
Just changed out the bulbs
BUCK'N PUMIE
TOW VEHICLE
GREY'S LOBOTOMY
Old 06-06-2020, 05:40 PM   #4
I’m thinking of doing the same.
Old 06-06-2020, 06:02 PM   #5
These are the lights i used Click image for larger version
ID:	230894Click image for larger version
BUCK'N PUMIE
TOW VEHICLE
GREY'S LOBOTOMY
Old 06-06-2020, 06:42 PM   #6
Thank you for sharing those, much appreciated.
Old 06-06-2020, 11:53 PM   #7
I also got these the pick lights for the outdoor kitchen, front storage bin and the overhead storage over the dinette.
Attachment 230922Attachment 230923
BUCK'N PUMIE
TOW VEHICLE
GREY'S LOBOTOMY
Old 06-08-2020, 08:11 AM   #8
Weekend Warrior
Greg Owen's Avatar
^^Bad Links^^
Just wanted to let you know your attachments are "bad" links--don't work.
Greg
2018 Palomino Puma 255RKS, being pulled by 2020 Ford F250 w/PullRite Superslide 5th Wheel Hitch.
USAF--25 years and counting!
Greg Owen is offline   Reply With Quote
Old 06-09-2020, 10:25 AM   #9
LED Running lights....ICYMI.
I replaced the running lights and brake lights on my 2109 Mini-Lite and wasn't real happy with the brightness. However I learned here that by adding metal tape, to the inside back that is black plastic, provides a reflective quality, and it significantly increases the brightness. Simple effective fix, especially if you have the tape. You could probably use the white part of the red and white reflective marking tape if you have that. It doesn't have to be pretty to be effective as it is covered by the lens.
hthavana is offline   Reply With Quote
Old 06-10-2020, 07:38 AM   #10
Thanks for the tip i'll have to take a look when i get a chance to hook up at night to see how it looks but so far with daylight conditions they are brighter than the halogens that were there in the first place
BUCK'N PUMIE
TOW VEHICLE
GREY'S LOBOTOMY
led, replacement
