11-28-2019, 09:14 PM
Black & Gray Tanks
Anyone out there know of a good black & gray tank sensor or probe cleaner that works good, iam getting inaccurate readings on those tanks due to dirty sensors or probes tryed a couple differnt ones, did not work my unit has not been used that much. anyone has any idaes please let me know thanks.
11-28-2019, 09:57 PM
use of your unit and knowledge of the past use is the best knowledge. I have not found a tank sensor yet that is worth a lot.
11-29-2019, 03:49 PM
I have found with the black water tank that a lot of water works will to clean your sensors in the tank. When we dump for the last time before breaking camp, I will us the black tank flush to clean the tank. As this is being done my wife is filling a bucket to dump water down the toilet. She usually dumps between 5 and 6 buckets full. The bucket size is approximately is a 10 to 12 quart bucket. This seems to keep the black tank sensors clean.
Now as far as the gray tank we just live with a 1/3 full sensor light lit.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
11-30-2019, 05:53 AM
See Level has the best reviews but none of them work great all the time. When the toilet starts to burp you're getting close!
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
11-30-2019, 06:08 AM
Fonzie
11-30-2019, 07:11 AM
I haven't depended on sensors to tell me when to dump the black tank. It tells me when it's almost time by burping when flushed. The grey water sensors seem to work but again I go when I think they should be dropped. I have gotten caught with the bathroom grey water filling up the bottom of the shower a few times but that was me not doing what I should have.
11-30-2019, 01:48 PM
After over 40 years of owning an RV of one type or another I have, after the first RV, never checked my holding tanks status with the gauges. You can tell when tanks are getting full by experience and proceed accordingly. No matter what you do, the tank sensors will eventually screw up and you're back to square one. I don't even try to clean them anymore.
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
11-30-2019, 01:57 PM
Originally Posted by fonzie
Works well for us. Also, during long stays with multiple black tank drops, I flush every tie. That helps too.
David and Vicki
9 year old Springer rescue Sydney
2018 Silverado LTZ 3500HD Dually Crew Cab Duramax/Allison stock "Polar Bear"
2019 Grand Design Reflection 337RLS "The Dog House II"
Andersen Ultimate 5th wheel hitch
EezTire TPMS
11-30-2019, 02:21 PM
I bought a 90 deg gargen hose fitting at home depot and put on a brass nozzle. I hook to the hose and step on the toilet flusher holding it open, turn on the nozzle then lower into the black tank turning it 360 deg. Seems to keep the tank clean and the sensors working.
Lee Hartwig
Ford V10
2009 Forest River Lexington
11-30-2019, 07:42 PM
Most of my stays are a month. After dumping for the last time before hitting the road. I add 1/2 cup of Dawn Dish liquid and 1/2 cup of Calgon water softener and 1/3 tank of water. I may even leave it in there for a day or two. Dump, rinse, and viola - sensors clean.
12-01-2019, 11:15 AM
On our last trip home we run with Black & Gray tanks with a few gallons of water / Laundry Detergent / Calgon !!!
12-01-2019, 12:41 PM
When I want a real good cleaning I use the black tank wash and washing machine hose that I put an end cap on drilled 3 holes at different angles insert in the toilet turn on and move around a bit works well and inexpensive to make
12-01-2019, 01:07 PM
Toilet Wand works well also !!!
12-02-2019, 09:36 AM
Toilet wand works good too, also use one but hose works well (have both).
01-07-2020, 10:25 AM
Rusty
X2
2015 Forester 2901
2005 Scion XB
01-07-2020, 11:16 AM
look down into the tank ...
I've never trusted any of our tank sensors, and now don't even look at them, ... the fresh water tank showed full before any water was ever put in it, it's translucent so I can look under the trailer to see it's level, ... I figure if we ever get backup in the shower(which we never have), then its full and needs dumping, ... and I look thru the toilet down into the black tank to see how its doing, I know not all toilets have a straight down sight into the BT, but ours does and that's a fool proof method to know the condition of that tank, sensors aren't always reliable, ...
getting a good look down into the BT was hindered by the water spray when the foot flush valve was pushed, UNTIL I installed a shutoff valve on that line, ... but that valve is handy in more ways than just that, if we ever have a flush valve leak, I can use that valve to control that area until we get back home or get the leak repair, without having to shut off water to the whole trailer, ... same thing when boon-docking and wanting to control water usage to the max, it gives me the ability to fully control the amount of water the toilet is using, ... a very handy and useful mod, ...
01-22-2020, 08:54 AM
You can try dumping a bag of ice in the tank before you leave on a trip or after dumping. When driving the ice bangs around in the tank and can clean the sensors off. It worked for me on my old 2005 Eagle. Once clean the tank sprayer is all I had to use.
I need to try the Dawn/Calgon thing too.
