Old 09-10-2015, 02:33 PM   #1
mikejm
Black tank handle
The black tank handle is becoming very difficult to pull out and push back
in. Is there a fix? Or am I heading to the RV repairman?
Thanks for any help,
mikemj
mikejm is offline   Reply With Quote
Old 09-10-2015, 03:26 PM   #2
Who Dares, Wins
doc73's Avatar
Silicone lube for the shaft and seals to loosen things up. They do need some care. Is it tough because of age or is the gate seeming to be bound up on "something."
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 09-10-2015, 03:58 PM   #3
I have heard that you can pour a bottle of veggie oil in the tank to coat the valve to lube it.....never tried it......
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 09-10-2015, 07:32 PM   #4
Who Dares, Wins
doc73's Avatar
I may be wrong but doesn't most tank treatments have seal lube in them as well?
2015 Chevy HD D-Max
Old 09-10-2015, 07:55 PM   #5
The lubricating thing sounds like the way to go. I would make sure I was "hooked up"prior to opening and closing that honey wagon
mike.t is offline   Reply With Quote
Old 09-10-2015, 08:00 PM   #6
trbomax's Avatar
Lubricateing the valves at every use with a non petroleum bassed lube will prevent this. Note that many silicone sprays have a mineral oil carrier that will swell and ruin the seals. Ive used "fluid film" on mine for the last 10 yrs or so ,it is lanolin, and Ive never, in nearly 50 years of doing this replaced a valve. Before "fluid film" I used "pam" or any other veggie oil cooking spray,but the fluid film rocks.And I do not sell it.
trbomax is offline   Reply With Quote
Old 09-10-2015, 08:16 PM   #7
For the uneducated like my self.
http://www.amazon.com/s/?ie=UTF8&key...l_43zs9e5yyp_e
Or.
http://www.ebay.com/sch/i.html?_from...+film&_sacat=0
Old 09-10-2015, 08:35 PM   #8
Tell us about "pam" sounds interesting.
Old 09-10-2015, 08:37 PM   #9
Left Coast
Have used cooking oil in commode....fixed leaking in to tank with valve closed....wouldn't hold water and valve was very clean
Old 09-10-2015, 08:41 PM   #10
Who Dares, Wins
doc73's Avatar
Just do NOT get it on the toilet seat!
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
Old 09-10-2015, 08:47 PM   #11
Left Coast
Like armor-all on steer'n wheel?
Old 09-10-2015, 08:59 PM   #12
Who Dares, Wins
doc73's Avatar
Yes! Or brake pedal... Or rear bench seat in your medic unit...
2015 Chevy HD D-Max
Old 09-10-2015, 09:38 PM   #13
Would you like to expand on this?
Old 09-10-2015, 09:45 PM   #14
Left Coast
Why certainly......the cooking oil softens up the rubber slightly and like a lite grease, fills any voids temporally... need to let it sit for a day or two in bowl. Been hold'n water for 2 months now.
Old 09-10-2015, 09:47 PM   #15
trbomax's Avatar
Pam cooking spray,Youve never heard of that? you need to go to the grocery store more often!
Old 09-10-2015, 09:58 PM   #16
I know what "pam" is. You used it how did it work compared to the "fluid"
Old 09-10-2015, 10:01 PM   #17
Always Learning
Can someone explain how you apply the spray? All I have is a handle at the end and it disappears behind my enclosed bottom...?
I have a blank tank oull they is really getting to be hard to push back (and pulling is a little difficult.
Old 09-10-2015, 10:09 PM   #18
CCRVOC
Ramblin Recks's Avatar
I had same problem. I had to pull the handle so hard I thought it would break. I tried spraying some lube into the cable but to no avail. When at Goshen, the fine folks at Cedar Creek replaced the cable (not the valve) and now it is a "two finger" pull/push.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 1000w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 09-10-2015, 10:11 PM   #19
trbomax's Avatar
Fluid Film is light years ahead of pam.I use it on hinges,locks,chain drives and sprockets,anything that moves . Its the only spray lube in my tool box (in the toy hauler).I guess the biggest thing is the little wand you can insert into the nozzel so it doesnt spray where you dont want it.
Old 09-10-2015, 10:18 PM   #20
Make sure all of your tanks are empty. Open the valve (pull the handle) spray what ever you are using on the shaft and close and open several times. Repeat other tank valves.
black, black tank, tank
