06-10-2015, 07:01 AM
Ceiling fan
When I first turn on my ceiling fan in my Sabre the blades rotate clockwise which I believe is the winter setting. I half to reverse the blades so they rotate counterclockwise. I do this by pressing the reverse button located on the same plate with the on/off switch and the speed switch. Is this normal or could it be wired backwards?
2012 F250 Super Duty
2013 Sabre 33CKTS
06-10-2015, 07:06 AM
Not sure chuck, my speed and reversing switches are still on the fan.
Which requires standing on a step stool.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
06-10-2015, 07:17 AM
I'm not sure what you are asking. The reverse button just reverses the fan from the current direction it's spinning.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
06-10-2015, 08:48 AM
Correct..but the default direction of the blades when you first turn on the fan is clockwise or winter. It draws down warm air from the ceiling. Everytime I turn on the fan I have to also reverse the correction the blades are rotating.
2013 Sabre 33CKTS
06-10-2015, 08:49 AM
Direction the blades are turning
2013 Sabre 33CKTS
06-10-2015, 09:56 AM
So it always defaults one direction after being off?
TURBS
2011 32bhok Sabre
06-10-2015, 10:38 AM
I believe I was told that there is a default direction every time you turn it on. I spoke to the company that imports these things.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
06-10-2015, 10:44 AM
Yes when first turned on it defaults to a clockwise direction. I would like to change that to a counter clockwise direction.
2013 Sabre 33CKTS
06-10-2015, 10:45 AM
I would think that in a camper it would default to counter clockwise or summer rotation
2013 Sabre 33CKTS
06-10-2015, 06:28 PM
You need to order the Aussie version. It spins the other direction by default.
06-10-2015, 06:39 PM
I really thought this was much to do about nothing so I really didn’t put much thought into my response. In reality most ceiling fans blow downward (summer) when turning counter-clockwise. The blades should lead with the upside as they spin for summer.
Bob and Joyce
ATU Local 788
06-11-2015, 12:15 PM
I don't think they got it?
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
06-11-2015, 01:15 PM
I got it!
Just waiting for the op to respond!
Lol maybe he's googling "aussie fan"?
TURBS
2011 32bhok Sabre
06-11-2015, 01:20 PM
Lol...ok now I get it. :-)
2013 Sabre 33CKTS
06-13-2015, 09:00 PM
I don't use ours as it sounds like a thrashing machine!
2014 SABRE 32 RCTS-6 Platinum
2002 F350 7.3 Powerstroke
06-14-2015, 03:59 AM
Don't use our fan either. Seems to actually divert the ac cold air from my chair!
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
06-23-2015, 01:02 PM
After looking at other fans I discovered that the blades on my fan are "twisted" the opposite of them. Looking at the blades from straight on the left side of my blades is lower then the right side. So that means that clockwise is correct for summer afterall. Must be indeed an Aussie fan.
2013 Sabre 33CKTS
