03-02-2020, 09:00 PM
Columbus 295RL w/3 propane tanks!
We are in the midst of purchasing a 2015 Columbus 295RL and during the walk thru, the seller could not be there and had a neighbor show us the unit. We saw (3) 20# propane tanks: 2 on one side and 1 on the other. Are all 3 used for general propane needs? Or is on used for something specific? There is no outdoor kitchen; nor is there a BBQ.
Can any owners give me a clue?
-Rich
03-03-2020, 07:56 AM
They did this a way for folks that had trouble handling the larger 30lb bottles you basically still have the same amount of propane available just easier to handle and possibly exchange, like at Lowes or such. Yes it runs all the normal items that run on propane.
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2008 Smart on deck
03-03-2020, 10:59 AM
Thanks, dblr. So all 3 are connected together? Is there a 2nd regulator? Do they switch as each one becomes empty?
-Rich
03-03-2020, 11:13 AM
All three are connected together. There is a extra regulator as well. We almost bought the same unit but could not make a deal that was satisfactory.
03-03-2020, 11:27 AM
-Rich
As B and B said yes, there should be a regulator on both sides, I am not personally sure how the change over works on a 3 bottle system but on a 2 if both bottles are open they will switch over automatically, but keep a eye on the gauges as it is easy to run out completely.
2001 Kenworth T2000
2008 Smart on deck
03-03-2020, 12:06 PM
My guess would be all automatic. The pair would run out first then the single would take over and you fill the pair while the single is in service. Just a guess.
03-03-2020, 02:11 PM
Propane tanks
The two side by side tanks have a automatic switch over if both left open or on, the third tank is for back up, we leave our third tank closed or off until needed or if needed
03-03-2020, 04:08 PM
Three propane tanks
We have the same install in our Columbus. In fact, when we looked at the unit at the RV Show, it had four 20 lb tanks installed. Upon delivery, there were only three. Two curb side and one drivers side. When asked, I was informed that it was ‘against the law(?)’ to carry that much propane (80 lbs) in an RV with that type of tank. (I don’t know if they were stringing me along?). However, the system works just fine and I have never emptied all three in a season. Leave the two on the curb side open with the autochangeover valve serving it’s purpose. Drivers side tank is closed. I keep an eye on the auto change and have a tendency to refill when I note the valve has changed. The tank on the drivers side in my ‘emergency standby’. I only Open that if both curb side are empty. (I also swap the tanks Side to side once a year). I don’t know it they use the smaller tanks for weight/ convenience or due to keeping down vertical height of the compartment. (The tanks are below the bedroom floor - a 30 lb tank is higher could influence the height of the floor?)
Dave
2011 Ram 3500 Laramie Cummins. SRW
2014 Columbus F320 RS. 5th
2007 Corsair. 246 RKS. 5th
03-03-2020, 04:26 PM
Thanks, Dave.
Is the driver's side (single) tank connected to anything? Or is it merely a stand-by tank?
-Rich
PS Forest River told me that they went to the 20# tanks as a two fold convenience:
1) tanks are lighter and easier to transport
2) more places to get refill/exchange (Home Depot, WalMart, etc)
03-03-2020, 07:23 PM
Yes, they are all connected. If both curb side empty, just turn on driver side tank. It has it’s own regulator. It is plumbed across the front of the trailer to the curb side. The two tanks on the curb side are (on my Columbus) mounted on a tray / drawer that pulls out and makes access and removal of the tanks easy.
We love our Columbus .... probably the last big 5er we will ever buy. Very minimal problems / issues since new. We have now parked the Columbus on a seasonal site, so it doesn’t see many miles any more.
Dave
03-05-2020, 01:30 PM
The Columbus we're buying is model 295RL. The brochure says that all Columbus' have a pull out pantry. Have those of you with a 295RL found a pantry?
-Rich
03-07-2020, 05:04 PM
Dr. V
No Pantry
We own a 2015 295RL and love it. The third propane tank/drivers side has its own regulator and works on its own if you need it. It is very easy to remove and works great with outside cooking equipment that has its own regulator. You can buy the needed hose on Amazon. That’s a big NO on the pull out pantry...we were disappointed. I put shelves in the coat closet by the steps and it works great as a pantry. Enjoy!
