Originally Posted by cboss
I think the only problem is the OP doesn't know how to reset a GFI that is most likely downstream from the popup plug as it is in the kitchen where GFIs are really needed.
Correct. Hopefully another member with this same make of RV can help in knowing where the gfci is.
Most of the times the main GFCI is within a few feet of a sink. It can be underneath an overhead cabinet, on the side of a counter, and multiple other locations.
If the OP provides the exact year and model of his RV, there are multiple videos that some eagle eye may be able to spot this main gfci to help.
