Originally Posted by asr524
A flow meter only tells half the story....
Our tank is 100gal....when the flow meter say 87.6gal the water flows out of my overflow hose. I have seen more than 3.5 gal come out of the overflow after this, verified with a bucket...
Was the tank totally empty before you filled it?
On a lot of tanks there is a varying amount of water retained in the tank even after it's emptied through the drain valve. This is due to any sagging of the tank bottom between brackets.
This will of course vary from tank to tank but it's just the nature of the beast.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
