I just purchased a 2016 Palomino 315 RLTSEK. Really like it, but what the heck is a galley drain? All my previous RVs just had grey and black water tanks. Also I couldn't find a lever to open and close it. Help would be much appreciated.
That should just mean that your kitchen has it's own tank. At least that's the case for my Silverback trailer. It would be odd not to have a lever to pull for it. The water control station for my trailer has three levers, each labelled for the tank it works for. I wonder if perhaps you might find a remote lever right at the tank under the kitchen area? I say that as I also have a grey and black tank for the rear washroom on my trailer and their levers are back there, rather than in the water station. I hope it points you in the right direction!
Dave in SK
VE5DLC Trailer: 2011 Cedar Creek Silverback 35K Truck: 2006 Dodge 2500 TRX4 Cummins
Seasonal at Saskatchewan Landing Provincial Park
how many sewer hose connections do you have? go to each sewer hose connection and find the drain pipes that come out that sewer drain. now follow these drain pipes back to the tank and you will find the drain valves.
also, don't put any faith in the term galley. our trailer has a tank labelled galley that is dedicated to the washer drain. they appear to just use generic prelabelled control panel plates.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
On our Columbus 320RS, we have two grey water drain valves, one in the normal plumbing panel, and the other just underneath, and slightly in front of the panel. All three (including the black) drain through the same outlet.
Interesting to see that someone else is somewhat looking for info on a galley tank. I bought a 2022 Puma 32bhdb tt last Nov and waiting to use it come April. It has two bathrooms, outdoor kitchen and a galley tank that serves the kitchen. I also have two grey and black tanks. Forest River service tells me that I have a galley tank and that there is a handle hidden under by the slides. The underbelly is enclosed so following the piping to the tank is not an option. So I'm with you on this and still trying to find out but will probably have to wait till I use it come April. The not so funny part of this is that the dealer has no idea if I have a galley tank, I had to make many calls and finally got thru to FR service.
