10-26-2020, 03:34 PM
King Jack Omni Directional JDTV Antenna
My 2020 Puma 257RESS says that it comes with the "King Jack omni-directional HDTV antenna with built-in long-range signal finder and WiFi prep"...what does that mean?
I tried to get television channels when I first set up and couldn't get anything at all. I gave up and bought a Roku device but would love to know if it is possible to get TV without internet.
Did I miss a step in set up or is there something else that I need to buy to make this King Jack work?
2020 Puma 257RESS
2020 Ram 2500 4 X 4
Centerville, Texas
Living to work and Working to live!
12-20-2020, 02:59 PM
Antenna
we just bought a 2015 Columbus 340RK and found the same issue. It is probably something i haven't done or checked but i too cannot get any channels. I plugged in a Firestick and all is well but i would like to get the Antenna to work. Thanks
12-20-2020, 03:39 PM
Kanadian Kamper
If you can find your TV booster switch.....it should look something like this. (See below)
It’s usually found fairly close to the main TV....maybe just behind it. You have to turn the booster ON.....you might see a green light come on.
Then in the TV itself, go to menu and select “Antennae” as opposed to “Cable” when you might be in a campground offering cable.
Then run channel scan. You must run a scan every time you move locations of your RV.
THE
Ken and Terry
12-20-2020, 05:13 PM
About a year and a half ago my neighbor had problems with his King Jack on his 5er. Ten miles out of Anchorage, in his driveway, the OTA reception was pitiful. Every two minutes the picture would either disappear or pixelate. He checked connectors, traced coax and even replaced the Winegard switch plate. Nothing worked. He got the info off of my "batwing" antenna and ordered one from Amazon. Perfect reception! Those King Jack's are garbage.
2016 Salem 27RKSS
04-01-2021, 04:26 PM
I can add to this, if anyone is still watching...
We have the King Jack antenna as well, and yes, you have to power it on. There is a light as described on the coaxial wall plate, and also one on the bottom of the antenna, so it can be seen from the ground, outside the camper. One other thing to check is this. On our antenna directional control (located in the master bedroom) our knob arrow is opposite the direction of the actual antenna. I'm sure someone from the factory just put it on 180* incorrectly, but once I found that out, I usually have no trouble pulling in channels from 60 miles away or so, unless it's hilly terrain.
Best of Luck.
Me, the wife, & 2 daughters (12 & 7yrs old)
2019 Palomino Puma QBSS
2015 Silverado LTZ / Z71 w/ many upgrades
04-01-2021, 05:21 PM
Best of Luck.
The rounded end is the front of the antenna and typically that would also mean the arrow points to the rounded end. If this is not the way yours is then yes the knob is 180 deg out.
04-02-2021, 08:22 PM
You have an omnidirectional yet directional pointable antenna?
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
04-08-2021, 08:36 AM
Correct.
The arrow on the control inside the camper, aligns with the squared off end of our antenna. Which is not correct. In the picture below, my arrow on my directional control, points the same direction as where the "King Jack" sticker is.
04-08-2021, 05:59 PM
I have a king jack brand round top omnidirectional TV antenna. There is no pointing.
By definition, omnidirectional means no pointing.
04-19-2021, 08:58 AM
Correct, omnidirection = all directions, hence, no turning. Unfortunately it also equals no gain. The antenna performs equally bad in all directions.
Since electronics have become cheaper and smaller, to compensate for the no gain antenna manufactures have added pre-amplifiers to the antennas. This overall package is intended to give the user the convenience of not having to rotate the antenna in search of transmitter sites and still have good performance.
Of course adding a pre-amp to a directional antenna gives even better performance, but the antenna needs to be aimed at the transmitter site (usually outside of the city where the station studio is).
