Old 05-28-2021, 06:11 PM   #1
Lights
I have a new 2021 Columbus 366RL purchased 5/4/21.
I have lights that aren’t working: the step light, the basement light and the outside light at the basement.
Any idea what to do?
Sweet Tea is offline   Reply With Quote
Old 05-28-2021, 06:34 PM   #2
bikendan's Avatar
Since they are 12v items, have you checked the fuse panel?
Old 05-28-2021, 07:21 PM   #3
I have looked but not sure how to tell.
ID:	255568   Click image for larger version
Old 05-28-2021, 07:23 PM   #4
I went out and look at the basement and I found this red stuff has leaked on my battery cables and other wires. What is this?
ID:	255570   Click image for larger version
ID:	255571   Click image for larger version
ID:	255572   Click image for larger version
ID:	255573   Click image for larger version
Old 05-28-2021, 07:49 PM   #5
Kanadian Kamper
kenandterry's Avatar
That red stuff is hydraulic fluid for the operation of your slides and/or jacks.
With all slides/jacks retracted, you should find the fluid level up near the top of the container. DO NOT ADD FLUID WITH SLIDES/JACKS EXTENDED.
If you don’t have a digital meter to check your fuses, it’ll be difficult to know if one is blown.
Ken and Terry
kenandterry is online now   Reply With Quote
Old 05-28-2021, 08:08 PM   #6
Why is it on the wires, even the ones up high by the light, and will that have any reason why the lights don’t work?
Old 05-28-2021, 10:02 PM   #7
bikendan's Avatar
Do you not know how to check each fuse? I'd pull each one and inspect each of them.
Old 05-30-2021, 10:36 PM   #8
It could be that the tank was overfilled with fluid with the jacks extended. When the jacks were retracted, the excess oil would have sprayed out a vent in the reservoir tank. I doubt that is why the lights are not working. I would check the fuses with a meter (resistance [ohms] function). Especially the fuse marked pass-thru.
NavyLCDR is offline   Reply With Quote
light
