Originally Posted by roadwizard
First off Hi all, I just picked up an 09 a Palimino Thoroughbred 26' bunkhouse yesterday and the air conditioner quit. When you move the thermostat the unit just clicks in the ceiling, not to worried about it will just take back to the dealer unless someone might know whats wrong.
Does any one know where the fuse/breaker panel is if there is any?
Bob
Hi and welcome Bob.
I can only guess with the little inofrmation you gave about your AC not working.
1. Are you sure you have shore power? You can verify this by checking if your microwave works.
2. Have you looked at the circuit breaker panel and turned off and back on the AC Breaker? Sometimes it may trip and look like it is on but really in the mid position which is tripped. You MUST then turn it OFF then Backon to reset.
3. Do you have battery power? I think you do because the click you hear is the 12 volt thermostat relay telling the AC to turn on.
Here is a picture of my electrical panel open. It is located below the refrigerator. Just puch the door and it will flop open. See my breaker marked AC. You may have a 20Amp just like it. Check.
Hope this helps or at least a starting point for you.
Good luck.
