Congrats on New 2022 RR.
We picked our RR 392mb up on the 8th. It has all the options also... Full Body paint that says LOOK at me I'm here. The refer is a Samsung. The A/C blows cold air out the bedroom vent.(LOTS) The Solar prep is hooked up but, we don't have any panels yet. Myself, I would only use the solar to keep the batteries charged in storage. The ONAN generator is very quite. I can hear a low hum inside the bedroom thats all. The propane tank on the entry side is for the house use. (Stove, Hotwater, ect) the tank on the other side is for the generator. They don't cross connect and 30lbs tank are the only tanks that will fit.
I have ran the A/C on the generator for 7 hours and the tank was dry.
I would recommend that you push every button, pull every handle. Go up on the roof and inspect the rubber and caulking. Pretend you are using the unit for a 3day trip.
Issues I have:
1. Rubber roof was damaged, cut with a knife during paint prep. No one found it until I got the unit home. Being a paraplegic I could not inspect the roof. My wife found it.
2. The refrigerator was dirty, after my wife cleaned it she found the plastic insides UV damaged.
3. Vent fans unbalanced and knocking after I got back. Worked during walk thru.
4. The hot water heat was suppose to be a tankless unit, factory can't get them so they installed a gas/electric 12gal
I will miss the long hot showers.
5. The shower leaks like crazy. Get in and run the shower during your walk thru.
We really like the RR and hope to get the bugs out.
