Originally Posted by SeaDog
There could be several things stopping the box/dish from finding the signal. I would start first with ensuring that the outside sat connection and the inside connection to the sat box are the same and wires haven't been crossed somewhere. Make sure nothing is blocking the dish antenna and it is level with either the coax connection or handle (if you have one) pointing due north. good luck
You are spot on! I had the exact same issue, and removed the outdoor hookup and saw an orange wire connected to the satellite in connection, and on the inside connector marked satellite, it was a black wire. The orange wire was there but was on a different connection. After switching those around all worked perfectly.
