Old 08-26-2018, 06:54 PM   #1
Fifth wheel Height
I am looking for fifth wheel models with a max height of 12' 10'' in the 35'-37' range. Is anyone aware of a web site that would list these in general ? i have been searching each make and model separate but with dozens and dozens of makes and models it's a slow process
lonewold is offline   Reply With Quote
Old 08-26-2018, 08:05 PM   #2
B and B's Avatar
Hello Lonewold,
I have not seen such a search anywhere. One thing to consider is hitched height. My Fifth Wheel is 13 ft 3 inches specified on sales brochure. Newer trucks are very high compared to older ones raising the towed height.
B and B is online now   Reply With Quote
Old 08-26-2018, 08:18 PM   #3
If you are looking for a Forest River check their website for specs. On my Cedar Creek 38EL the website said 13' 5" but it turned out to be 13' 7" plus. I measured several times and got about as sophisticated as I could. Once you narrow it down if you have a hard height limit then make sure you verify and put in the purchase agreement that it must be a certain height or deal is off.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 08-26-2018, 08:46 PM   #4
Hi,
My 2014 33RL Silverback is 13'6" with vent covers -- the actual maximum measurement when hitched. I don't have access to the brochure that gives the factory height number, unfortunately.
I mention the vent cover specifically because my Fantastic Fan brand cover adds 10 inches, IIRC, to the location where it is installed -- in my case the tallest portion of the trailer over the bedroom. If not for that, the air conditioner housing likely would be the highest point, but I no longer recall that measurement when I took it several years ago.
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 08-27-2018, 01:18 AM   #5
SYE
SYE's Avatar
According to the spec sheet on Columbus, the tallest is 12' 6", however, this does not include any vents, AC TV Antenna heights etc, so you need to remember to add them too.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 08-27-2018, 01:35 AM   #6
SYE what is the total height of your 366Rl ?? i have been looking at the 298RLC which the spec sheets says 12' 4'' which i just assumed was the total at high point which is usually the ac unit.
Old 08-27-2018, 01:36 AM   #7
SYE
SYE's Avatar
My 295 was 13' 5" my 366 is 13' 6". Measurement while hooked up to TV
Scott & Vicki
2021 4 reserved
Old 08-27-2018, 07:08 AM   #8
(Dry Huunday)
DreiHunde's Avatar
Check out Coachmen Chaparral, they have a few that seem to fit your requirements.
Chaparral Fifth Wheels by Coachmen RV
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 08-27-2018, 07:29 AM   #9
Chaparral
thanks i have been looking at the chaparral 336tsik and waiting to get exact spec's at a dealer.
Old 08-27-2018, 07:58 AM   #10
68 Whiskey's Avatar
Welcome from Georgia, BTW. I currently have a chaparral 336tsik and its been a great trailer. A few items but overall a good one. Hitched it is 13' 6" on my truck and it's almost exactly level. I have the front AC. I checked the website and the specs show 12' 5". That's probably about right. Let me know if I can help further.
Happy trails and safe travels
'17 Coachmen Chaparral
'17 Silverado 6.6L Duramax
Retired & Full Timer
KI4OVB
68 Whiskey is offline   Reply With Quote
Old 08-27-2018, 08:08 AM   #11
onetonford's Avatar
When I bought my Wildcat it was advertised as 11'11" however after getting it home Found out the hard way that it was higher after I hit the roof fasia board on the carport. After some minor damage to air conditioner. I got a 2 X 4 and level measured to ground and found out it was 12' 4" so the numbers on the website is the top of unit high point and not the air conditioner.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-27-2018, 08:09 AM   #12
Yes, take the heights with a grain of salt.
My Cedar Creek Hathaway RE34 was listed at one height and did not include the factory installed second ac. Also all modern trucks are tall, which can raise the height.
Lots of fivers were designed 20 years ago and must be raised a lot beyond level. You have to level the fiver and measure to the bottom of the Unit to compare. This dimension is never displayed. Sometimes you can get pin height. Another gotcha. More expensive units are more accommodating.
At one point many fivers were less than 60” to the unit at one the hitch. Most modern heavy duty four wheel,trucks are near 60” at he side rails.
I wanted an Open Range light but, it would be 4-6” nose high. Not ok.
Be careful.
Research, research. You cannot sort by height.
In the fiver world there are lots of gotchas.
tomkatb is offline   Reply With Quote
Old 08-31-2018, 04:41 PM   #13
68 Whiskey's Avatar
Yep, exactly, verify when it comes to the height, weight, etc. I always use a tape and a 2x4 to measure the exact height from the pavement to the top most point. A level parking lot is where I go.
KI4OVB
fifth wheel, wheel
