Old 01-15-2019, 01:02 PM   #1
longdriver's Avatar
Interior LED lights
Saw a post about dimming interior LED lights cant seem to locate it. Any ideas to the link. Thank for the help in advance
longdriver is offline   Reply With Quote
Old 01-15-2019, 01:03 PM   #2
longdriver's Avatar
Well that header note went wrong
Old 01-15-2019, 01:21 PM   #3
bubbles's Avatar
I installed one of these. It will dim LED/incandescent/halogen. Can accommodate 7 amps. Just connect the existing switch wires to it and add a ground wire and good to go. Went to a trophy shop and had a 1/8 inch thick custom (verbiage) mounting plate made for it ($7). Drilled the shaft and screw holes. Works as advertised from ebay supplier. It is $39.90 (no tax/no shipping) from ebay so it's not cheap. May be available from other suppliers for less. Body shape is oval not round. It goes from full bright to full dim and click to off.
Old 01-15-2019, 01:43 PM   #4
longdriver's Avatar
Thanks. But the one I saw was an rf mod that plugged into lights themselves and a fod to dim them.
led
