Originally Posted by Miss_crystalina
How would I hook up my portable propane BBQ to the gas line at back of my trailer? What would I need?
Is your BBQ one that came with the trailer or is it aftermarket?
Usually the one that comes with the trailer comes with the supplied quick disconnect hose and the BBQ grill works of the low pressure port on the trailer.
you simply connect the two and you are good to go.
Aftermarket type grills are usually high pressure (separate bottle) and require some modification to utilize the low pressure port.
As mentioned, if you are looking to hook up an high pressure grill to your low pressure port, there are lots of prior discussions here on this.
