09-30-2016, 10:44 AM
Sunseeker 2400MBW
Reflectix-Dangerous for seals and glass??
Hi all,
My husband and I have discovered Reflectix for making our own sunshades. There is a remarkable difference in how much cooler it is inside when these are up.
However I read a terrifying article this morning: opinions please!!!!
https://arizonarv.wordpress.com/2010...out-reflectix/
Reflectix is a great product when being used for it’s intended use as a reflective insulation or radiant barrier. It is not intended for use in residential or RV windows. When used on the inside it can break any window whether it is single or double pane. The heat radiated from it will not dissipate through the glass at the needed rate, it will continue to build and eventually the glass could break. It is however, more common for double pane windows to break. It can also ruin window tint or film because of the excessive heat build up.
Windows that have Reflectix used on the inside will radiate enough heat so that the excessive heat can be felt up to 6′ away depending on conditions. The surface temperature of the glass can exceed the surface temperature of the wall by 30 to 50 degrees when the outside temperature is approximately 95 degrees.
Windows that have a 90% UV shade fabric will be approximately 30 to 50 degrees cooler than a window using Reflectix. The benefit is you will actually be cooling rather than heating the interior of your RV or home and not causing any damage. When your windows create enough heat to break the glass it is not unlikely that any rubber seals or sealing compounds used for keeping moisture out will be damaged. The other benefit is outside window covers that offer privacy and can be used all year long and do not leave a messy residue on everything they come in contact with.
The choice is yours to make based on your circumstances and needs but, now you have a little more information to help make your decision when purchasing window covers.
used to be - Full time 2016 Sunseeker 2400WS towing a 2018 Subaru Forester. 2021 we bought a house.....Still have the precious Sunseeker and tow car.
09-30-2016, 10:47 AM
Always Learning
I've used Reflectix in many windows for 2-3 years now; including 90+ degrees in Florida in direct sun.
IMO, this is posted by a dealership who wants to sell you something. As such, their information is biased and suspect.
I will say, we've had some transfer of silver coating to the windows. Nothing major, but a spot here or there.
09-30-2016, 10:49 AM
We use reflectix in our HTT canvas ends only. Obviously not a concern.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
09-30-2016, 10:55 AM
Sunseeker 2400MBW
They DO sell window coverings. And it's in Arizona, hot place. But it kinda makes sense.
Another thing about interior coverings, you don't have to go outside (in your PJs) and remove a covering when you're ready to see outdoors.
I don't know, it's always something. We have a cover for the winter, but in the summer 1/2 the front and passenger side gets several hours of direct baking heat.
09-30-2016, 11:22 AM
Who Dares, Wins
Have covers for all our window and skylights. Huge difference. Been like this for 2 years, no issues.
2015 Chevy HD D-Max
2022 Impression 315MB
09-30-2016, 11:27 AM
I think their problem is that they're using the Reflectix on window "pains" and not window "panes!"
(Nancy apparently fixed their error in her quote!)
And remember, SOME of us are using Reflectix to keep heat IN, not OUT.
2011 Traverse LT, 3.6L, FWD
09-30-2016, 11:52 AM
We use reflectix panels in our windows. No issues, even on multiple 100+ degree days.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
09-30-2016, 01:10 PM
...And a meteor can fall on you, or the Chinese Space Station could deorbit right on you... The chances are mighty slim. Even anecdotal evidence would help to add some weight to this opinion. There was none provided.
I wouldn't worry about it.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
09-30-2016, 01:36 PM
I haven't seen this stuff under the Reflectix name, but it's basically just bubble wrap with aluminum foil on both sides, correct? I have some that I purchased at an HVAC supplier for duct insulation. Enough to make a panel for the windshield of my Pursuit if it's the same stuff.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2019: 76
09-30-2016, 01:56 PM
I believe that this will not be a problem with windows that are tempered. Any window that is operable will need to be tempered. If the glass is standard annealed glass then yes the heat buildup may cause the glass to break especially if there is differential shading on the glass.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
09-30-2016, 02:10 PM
(o˘◡˘o)
Sure hope somebody warns all the unsuspecting people who bought the number 1 selling windshield shade on Amazon
https://www.amazon.com/Hippo-Windshi.../dp/B01CSDYD04
Looks like reflectix material there also
09-30-2016, 02:53 PM
We have tinted all the windows in our RV and have used reflectix placed between them and the shades during 90+ temps with no problems during the three years we've been doing it.
09-30-2016, 02:59 PM
Now why would a reasonable person doubt this "warning" from Sunpro; a company that sells an alternate products to Reflectix? There could be an agenda hidden here, ya think? So, I asked my son-in-law since he represents a manufacturer that makes various film products. About their products they don't recommend any film with higher than 50% heat absorption on double / triple insulated windows. So, although I would like to bust the Sunpro statement, I am not so sure that it is true or not, but it seems reasonble Reflectix could cause cause a problem. Now, I have single strength and won't be getting ride of my beloved Reflectix.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
09-30-2016, 03:56 PM
One option is to put the Reflectix on the outside of your window shades, so the reflectix isn't directly against the windows.
09-30-2016, 04:11 PM
One could cover the Skylights with Eternabond which would prevent any sun coming in and protect the skylights. As indicted, we have curtains on our side windows that works pretty well and also we can see out them.
We are driving a Ford F250 Gasser and pulling a Evergreen G269FK. We also have a Cairn Terrier. 2 Champion Generators. This year, planning on 6 months in our Evergreen visiting, California, Michigan, and Ohio. We live in Florida. Grandkids, and dog are why we camp. Also have a Hensley Hitch which that eliminates all sway. Pricey, but worth it.
09-30-2016, 06:26 PM
Pretty much... the shiny stuff is silver Mylar plastic. Some light gets through... maybe 10%. Its the stuff many windshield sun shields are made of.
WW
Hyper Lite was sold
09-30-2016, 06:28 PM
The stuff isn't designed for outdoor use and will not hold up out there. There are better products for outside.
WW
Hyper Lite was sold
09-30-2016, 07:08 PM
This statement alone would cause me to discount the entire review.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-30-2016, 08:47 PM
Reflectix-dangerous for seals and glass?
My Dad has used this product inside his windows on his motor homes for the past 20 years at least, maybe even 30. He lives near Palm Springs where temps have topped 114 degrees regularly. Never had a problem with his window glass. I agree, sounds like hype from a competitor trying to sell their product. Pretty shady to me! 😎
09-30-2016, 10:23 PM
Sunseeker 2400MBW
Well, that's why I posted that question. Collectively there is a lot of experience here. Personally, we love the silver bubble wrap and we want to take care of that MH. And I don't want to be Chicken Little.
