Old 02-14-2018, 11:34 AM   #1
Miss_crystalina's Avatar
RV SWIVEL MOUNT replacement
I currently have this set up. Click image for larger version
ID:	162396Click image for larger version
I would like to get a swivel mount. (The tv pictured isnít the one we use. The one we use is 32 inch)
Miss_crystalina is offline   Reply With Quote
Old 02-14-2018, 11:35 AM   #2
This is what I need and donít know where to look Click image for larger version
ID:	162398Click image for larger version
Old 02-14-2018, 02:58 PM   #3
From what I see is just a standard tv swing mount. Available everywhere. Just google tv swing mount and find which one you need for the tv you plan on using it for. Hopefully this is what you are asking.
whitewinghunter is offline   Reply With Quote
Old 02-14-2018, 03:47 PM   #4
Head Rambler
Can you tell what the logo is on the wall puck?
It looks like an LV but I can't tell.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 02-14-2018, 04:10 PM   #5
Originally Posted by Miss_crystalina View Post
This is what I need and don’t know where to look Attachment 162398Attachment 162399
Are you looking to attach this this swivel mount to the block you showed earlier or are you simply looking for a swivel wall mount?
The swivel model you referenced doesn't seem to have a wall attaching plate.
It seems like it would mount/latch onto something already attached to the wall. (hence the question about your current block)
Where did you get the drawings?
Days Camped: '18=51 '19=58 '20=110 '21=60
Old 02-15-2018, 01:42 PM   #6
rvrobocop's Avatar
Two years back I had to replace my front TV. Went much bigger and wanted flexibility and utility. I bought the exact mount you want to upgrade to. Can't recall if I got mine at Wal Mart or Best Buy. Did not find it online. Just did a quick Amazon search and did not see it either. I love it since I can easily slip off the 30" TV while traveling.
Scott
2011 Sunseeker 3170DSF
2002 Honda CR-V
"Do not mistake my benevolence for weakness."
rvrobocop is offline   Reply With Quote
Old 02-15-2018, 01:45 PM   #7
Itís. So convenient!!!!
Old 02-15-2018, 11:09 PM   #8
Stormrider151's Avatar
MorRyde has what your looking for. I got mine from them because it is very sturdy and locks in place when traveling.
Stormrider151 is offline   Reply With Quote
Old 02-15-2018, 11:36 PM   #9
camaraderie's Avatar
Remember that RV interior walls ain't like those in houses. No matter what you buy you will need to find a way to support the mount from behind so it doesn't rip out of the wall. If you have access to the back of that mount position then a small piece of plywood or steel/aluminum is advisable as a backing plate.
This: https://www.amazon.com/Mount-Lockabl.../dp/B01F2OZ0VM
Lockable on the road.
________
Cam
2015 Georgetown 280DS
camaraderie is online now   Reply With Quote
Old 02-17-2018, 10:29 PM   #10
Try: MONOPRICE.COM They have a very big assortment of mounts for all sizes of televisions. Prices are the best I've found anywhere and their delivery is pretty fast as well.
ProfChuck is offline   Reply With Quote
Old 02-19-2018, 06:42 PM   #11
Head Rambler
Those mounts are Kebloc mounts. There is a thread about them and where to get the parts.
Here's the thread. Anyone know where to buy Kebloc Mounts
Gotta go campin!
mount, replacement
