09-29-2018, 09:13 PM
#101
Yupurs , I saw your old post about the antenna to use and the mounting the J pole you were talking about would work very well I mount mine on a section of PVC pipe attached to the ladder i run the pipe thru a coupler about mid way up the ladder and use an end cap to hold it up fast and easy and simple to install will work for most antenna installation you want .
My wife and I are both ham radio operators and we use handhelds to communicate while camping and use something like a buddy pole with two ham sticks for HF the pole and tripod are MFJ using a small auto turner works great for us
My name is Ron. Call kd5fpm we use a yaesu FTM-100 in the trailer and alinco SR9 this set up works great for us
Hope this helps you a little
09-30-2018, 11:00 AM
#102
K1PDB. Mostly an appliance guy (use it for Emergency Management) but have a small dual-band mobile in the TV and usually a Baofeng portable in the fifth wheel. Maybe something I'll want to play with more in retirement. Saw someone with a big dipole strung up at the Elkhart KOA this summer but didn't get a chance to talk to him.
09-30-2018, 11:57 AM
#103
To K1PDB You can talk quite a distance just on a handheld using a outside antenna I made one out old brass brazing rod soldered on an SO239 connector mounted on a pvc pipe it's just a ground plane antenna but works great cheap and easy it's all fun good luck
Ron kd5fpm
Ron
2014 Ram 1500 4X4
Rockwood 2304 mini
Kd5fpm
10-03-2018, 08:14 AM
#104
Three in our on family are licensed. Myself, VE5DLC, my wife VE5YAK, and my oldest son, VA5KMG. We run dipoles when camping and operate with a Kenwood TS-480SAT, just working HF on 20m and 40m. With the sun hitting the minimums in the cycle it's been a little harder but we do still get a little DX occasionally from southern SK.
Dave in SK
VE5DLC
Trailer: 2011 Cedar Creek Silverback 35K
Truck: 2006 Dodge 2500 TRX4 Cummins
Seasonal at Saskatchewan Landing Provincial Park
10-03-2018, 08:40 AM
#105
KD0SCC. I have a quad band in the TV with a dual band antenna. I carry a ht most of the time. Use mostly for emergency management in our area. No mag mount for me. I bit the bullet and drilled a hole in the truck roof for a permanent mount.
2006 Silverado 2500HD
2014 Flagstaff 21FBRS
10-03-2018, 09:17 AM
#106
I run a Yeasu FTDX 1200 with an eagle one from the new home. I had my rig and computer mounted to an end table at the house. When we went full time in the RV, I just moved the whole setup into the RV. This is not the most flattering photo, but you can get the idea.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
12-29-2018, 12:05 PM
#107
Hello and 73! KK5FE here from south Louisiana. Just found this thread. I haven’t been active for a while for one reason or another but have been licensed since ‘93 or so. Don’t remember exactly.
I still have my small Yaseu 840 that I think I’ll bring along with me next time we head out. I’ll have to come up with an antenna of some sort.
12-29-2018, 01:29 PM
#108
WD4PRT in NE TN with 144/440 in truck; working on putting HF in trailer.
01-18-2019, 09:38 PM
#109
I have this set up in my pick up.
Top picture is my pickup, next picture is in my work truck, last picture is for my camper.
KN4JQU
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
01-18-2019, 10:24 PM
#110
Originally Posted by tugboat369
Man, love to see that TS-430S. I had one for years and finally had to let it go a couple years ago to thin the herd before DW would let me get a TS-590S.
N8OHB
Tony & Brenda
2017 Ford F-250SD 6.7 Power Stroke
2018 Flagstaff 29KSWS
Happy Camping!
01-18-2019, 11:33 PM
#111
I will look into the Super antenna. Never heard of it before. I have not tried HF mobile yet.
01-19-2019, 02:34 AM
#112
RV Ham Radio
Have call sign and 146.52 posted on the back of our MH, and 11,000 miles later, have yet to have a passing ham call.
When stationary in campgrounds, have had good success in giving a shout out on simplex and getting responses.
01-19-2019, 06:46 AM
#113
AB4GR - extra class. Started out in 1972 as WN4AJQ, upgraded to General then Advanced - WA4AJQ. Once I had my code up to 20+, I tested for Extra and got a new call sign. Not as active as I used to be but still get on the air. Have never operated while camping but might in the future.
01-19-2019, 01:13 PM
#114
I have one of those KT8900s mounted inside the center console of my Sierra. Nice little rig at a bargain price.
01-22-2019, 12:21 AM
#115
KM6OSY
01-24-2019, 09:16 PM
#116
QuartzFest outside Quartzsite, Arizona. Nearly 1,000 hams and family/friends. I’m in that photo someplace.
3’s & 8’s Brandi W6FPT
03-21-2019, 08:30 PM
#117
KB9VGD here is SE Wisconsin.
Gary R. Oaks - KB9VGD
Racine Astronomical Society
American Radio Relay League (ARRL)
Walworth Co. ARES/RACES Public Information Officer
ARRL Registered License Instructor
Lakes Area Amateur Radio Club
Racine Amateur Television Society
British Amateur Television Society
03-22-2019, 06:42 AM
#118
Camper
NG2S here
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
03-22-2019, 08:43 AM
#119
N9GTJ
N9GTJ from east central Indiana here. Delaware Co. IN ARC and 220 Mafia
Cbetmoose
2018 Heritage Glen 24bhhl
2015 Ram 2500 6.4liter, SB, 3154 lbs payload
Me, DW, and 55lbs of Sofie the Goldendoodle.
03-22-2019, 08:57 AM
#120
Mobile Ham Operations
Hi my name is Ron KG4QIV been mobile haming since I got my license over 20 years almost. I have an Icom 706 MKIIG which will do all HF bands, 2 meter and 440 all modes. I have the passenger side of my RV setup with Icom equipment in the overhead bin and Eagle One HF antenna and 2 meter 440 antenna on top of ladder in the rear. Run power cables direct to house bank to eliminate noise and will allow you to operate while both on the road and when parked.
Get an HF antenna that is easy to put up, Eagle One bolts to trailer hitch or rear ladder. MFJ make a big ears portable HF antenna that you can put on a speaker stand and tie down with ropes and tent pegs.
Again simple light weight and quick deployment, if not you will not use it.
Small HT portable is good to use so wife if she is a ham and give you voice commands when backing in tough situations over the air and you can hear her. I am working on putting a laptop in and sound card interface so I can do FT 8 and some of the digital modes. There are some good books on install mobile equipment in the ARRL library. Baofeng has some small portable units no for almost $40.00 dollars very cost effective and can be used to take with you if you go hiking or if someone stays behind in the rig again both have to be licensed. So many uses. 73 Ron
