Originally Posted by Nick Danger
Seems like a lot of "stuff" in the front window. I only have 2 power outlets in the dash. Garmin gets power from a USB port. Rear camera already takes up one power spot. Can you use a splitter on power supply?
Which brand and model is most recommended? Is Amazon the best place to get one or someplace like Auto Zone? What size as card will I need for at least 8 hours of travel? Do they record on a loop like CC TV? I assume you can just remove SD card and copy to laptop if needed?
Thanks in advance for all the great contributions.
Id make sure your dash camera has a feature that will allow LOOPING where is simply overwrites the data on your SD Card. Oldest 1st.
Most good quality camera will do this. Look on Amazon (reviews) Vantrue is excellent too
Each Camera will have a recommended SD Card size and capacity. Get the largest one you can that is compatible. Gives you more than 8 hrs cheap..
Yes, typically you pull the SD Card put it in a USB adaptor to your computer.
Some Cameras have software that will show your video where you can print, copy ect... and GPS Mapping. Again Partial to Vantrue Cameras
As for power, Id run the power to a 12v location in your fuse box. Use add-a fuse to a item that turns on when you turn the ignition maybe the Wipers or something like that. Plenty of videos online to show you how to install a add-a fuse.
Best of luck
