Old 01-27-2023, 11:32 PM   #1
nvs4602's Avatar
Smoke detectors do age out
As the title states, and they can do it at the most inopportune time. We had left on vacation and driven about 250 miles for the day. Stopped at a KOA for the night. When we woke up the next morning our security cameras at home notified us of noise detected inside our house . A couple minutes later another notification from our downstairs camera. When we watched the video we could hear our smoke detectors going off. This is a scary feeling when your far from home. Luckily I keep the local sheriff's number on my phone. Because calling 911 where your at only gets you that areas 911 not your home town. They dispatched the fire Department. Who have the means to enter your locked home without a key.
Lucky for us, no fire. But all of our smoke detectors, which are tied together so if one goes off they all do, were blasting away.. what to do about that? We made the decision to head back home to find out what had caused the issue. What I found is that the detectors must have aged out and when one went off they all did. So now we have all new smoke detectors one of which is now a carbon monoxide and smoke detector.
So I guess what I've learned is.
1. replace your detectors every 10years ours where 25 years old.
2. Keep your local police and fire Department numbers handy, even when away from home.
Hope this helps keep someone else from the same scare and trouble.
nvs4602 is offline   Reply With Quote
Old 01-28-2023, 12:16 AM   #2
Thanks for sharing. Thankfully it wasn't something worse.
Most smoke and co detectors the we've purchased are rated for 10 years.
We usually give a key to one neighbor and tell a couple more who has the key in case of emergency. One year, a freeze caused pipes to burst in homes where people were out of town for the holidays. Good neighbors turned off water because the fire and water departments were backed up for days with reports of water running out front doors.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 01-28-2023, 08:32 AM   #3
Flybob's Avatar
Some states/ jurisdictions have laws that require Smoke Detectors to be replaced every 10 yrs. One of those " I never knew that laws".
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-28-2023, 05:00 PM   #4
Probably another of those laws that is impossible to enforce without mandatory inspections.
You'd think that common sense would trump the need for a law like this.
Then again, we all know what's no longer common today.
Sent from my SM-N950U1 using Forest River Forums mobile app
2004 Nissan Titan
Old 01-28-2023, 05:10 PM   #5
I seem to recall that homeowners insurance gives a discount for installed smoke detectors. Now should one have a loss and the insurance company discovers the smoke detectors were not maintained, they may deny coverage. The fire department will always check for operational smoke detectors.
Bob
Bob K4TAX is offline   Reply With Quote
Old 01-28-2023, 06:16 PM   #6
Flybob's Avatar
Or inspections done as part of a home sale.
TST Tire Monitors
2 100W solar panels
Old 01-28-2023, 07:17 PM   #7
Bob
Not sure about smoke detector discounts but my insurance company gives a decent discount for a monitored fire alarm. I do have to provide a certificate from alarm company annually but I can do that all electronically.
2004 Nissan Titan
Old 01-28-2023, 07:20 PM   #8
Scoundrel
HangDiver's Avatar
Had something similar happen recently. Our home is only 2-years old but the batteries in one of our four detectors were low. So at 5:00am in the morning all four detectors decided it was time for us to get up.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 01-29-2023, 10:01 PM   #9
For years I always wondered why low battery alarms always went off during the wee hours of the morning. Then it dawned on me what the likely reason was. If one uses a temp set-back feature on their thermostat, or just turns down the heat manually, 3-5AM is about when the house is the coolest (especially in winter) and most batteries have a drop in voltage as they cool. Especially one that's at or close to end of life.
The one that really ticks me off is the one high up in my living room's cathedral ceiling. When it goes off it triggers the other six which are all interconnected.
2004 Nissan Titan
Old 01-29-2023, 10:52 PM   #10
Scoundrel
HangDiver's Avatar
Never thought of that but you may be right re: time of day/evening cooling.
