Old 04-24-2018, 06:24 PM   #1
Wiring LED lights
Wiring in some LED lights that dont have much draw. About an amp total. Didn't know if I could run the wires (18 awg) straight to the 12v battery or tie into an AC-DC power supply with a simple switch. Didn't know if anything needed to be in the circuit like a fusible link wire, fuse block or whatever. It's a small wire and dont think a smaller one could be found. Any thoughts
OKI Marine is offline   Reply With Quote
Old 04-24-2018, 06:29 PM   #2
You want a fuse as close to where you are picking up power as possible.
Just imagine a short to ground along the entire length of the wire you are running. Put the fuse where it will protect that entire length.
I usually run 16ga for lighting wiring. It's not really for the current capability but since it is bigger, it's stronger. Less likely to damage.
babock is offline   Reply With Quote
Old 04-24-2018, 06:30 PM   #3
For a wire that small what size fuse would you suggest ?
Old 04-24-2018, 06:32 PM   #4
15A for 18 gauge
20A for 16 gauge
That is max size. If all you have is a 5A draw, you can obviously use something smaller.
Old 04-24-2018, 06:33 PM   #5
Nurek's Avatar
Where are you putting this LED light?
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 04-24-2018, 06:33 PM   #6
15A for 18 gauge
20A for 16 gauge
Thanks. I'm assuming that ties into the positive wire?
Old 04-24-2018, 06:35 PM   #7
There are 8 total lights (marker lights) that I installed on my lippert solid steps.Click image for larger version
ID:	169467Click image for larger version
Old 04-24-2018, 07:16 PM   #8
Correct.
led, light, wiring
