-   Modifications and Updates (https://www.forestriverforums.com/forums/f68/)
-   -   Turbs awning pole install with pics. (https://www.forestriverforums.com/forums/f68/turbs-awning-pole-install-with-pics-102583.html)
TURBS 03-08-2016 06:22 PM
Any questions or comments you may have about the following installation can be best answered in the following thread link:
https://www.forestriverforums.com/for...les-85132.html
Awning hold down poles.
Remove upper awning bolt.
https://uploads.tapatalk-cdn.com/2016...fff42a9833.jpg
Install upper bracket and just snug.
https://uploads.tapatalk-cdn.com/2016...917d76c5b1.jpg
Install bigger upper pole that has the hole closest to the end with supplied stainless 1/4-20 x 2 bolt and lock nut
https://uploads.tapatalk-cdn.com/2016...0fca110501.jpg
https://uploads.tapatalk-cdn.com/2016...25dfdb50a7.jpg
Install lower bracket and pin but do not lock pin, also do not install lower pole yet.
https://uploads.tapatalk-cdn.com/2016...f297e89f46.jpg
While holding bracket firmly in place remove pin and pull back on upper pole to mark two holes for rivet " a helper comes in handy here"!
https://uploads.tapatalk-cdn.com/2016...6cd6b79472.jpg
Drill holes and pop rivet lower in place.
Remove pole at upper mount carefully not to disturb position and drill lower hole in upper bracket and rivet into place.
Now tighten upper mounting bracket bolt and reinstall upper pole and just run locking nut down to just about touching.
Insert lower pole into upper and align stow holes and insert pin!
https://uploads.tapatalk-cdn.com/2016...1000e97a2e.jpg
Done!
Repeat on second pole!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
https://www.forestriverforums.com/for....php?p=1124361
2015 Columbus 320RS
2008 2500HD Duramax
TURBS 03-09-2016 07:29 AM
This is a typical dometic install .
I'll also be working on a carefree style install.
2015 Columbus 320RS
2008 2500HD Duramax
