-   -   Broken steps (https://www.forestriverforums.com/forums/f110/broken-steps-103154.html)
thunderstruck 03-16-2016 10:15 PM
Broken steps
Top pivot on Main steps broke Just wondering if anyone else has had this issue. Looks leverage broke upper tube
Unit is a 2014 Rockwood 2604WS
bob caldwell 03-16-2016 10:20 PM
usually the rivets fail......when they do, replace with a grade 5 or better bolt and ny-loc nut. some people use a step support also
Lookng4us 03-17-2016 01:21 AM
My steps on our Rockwood did the same. What I did was drilled out and put a Allen bolt and nut. Allen are harder than must nuts and bolts plus I had to watch my space to make sure it worked.
RSchleder 03-17-2016 05:12 AM
We bought a new Wildcat Maxx in 2014 and traded it for a longer Maxx unit in 2016. When we first climbed the steps in our 2016 I couldn't believe how flimsy the steps felt compared to the 2014. I use 2 step supports, side by side, about 10-12' apart between the bottom step and the ground. This makes the steps very solid and should save them from being over-stressed/broken. So far, so good!
youroo 03-17-2016 06:13 AM
4 Attachment(s)
The more steps,the more Leverage! Our steps still have the O/E rivets,but we have had the Steps supported since Day 1,Lots of Leverage Movement when going In/Out,Without Step Supports!:signhavefun: Youroo!! :us-flag-waving:
Mr Havercamp 03-17-2016 07:02 AM
That's because they say "Flexco". They evidently are living up to the name that's on them.:roflblack:
I figure by the 2018 model year the steps will be either made from luan plywood, cardboard, or no steps will be provided. They'll just give you one of those plastic step stools that cost $.99 at Wally's.
bob caldwell 03-17-2016 07:18 AM
Rope ladder or cargo net
Sent from my XT1080 using Tapatalk
youroo 03-17-2016 07:28 AM
Try these Bad Boys! :roflblack: Youroo!! :us-flag-waving:
bob caldwell 03-17-2016 07:41 AM
Pogo stick would be handy there...
Andy52 03-20-2016 11:28 AM
I have a 2014 Silverback 29RE. My steps top tube broke as you described. The steps were replaced under warranty.
Andy
Too Tall 03-25-2016 10:14 AM
Wouldn't it be nice to have things designed to last longer than the warranty period,
bob caldwell 03-25-2016 10:38 AM
Well, at least we now have a pattern!
retiredcamper47 03-25-2016 03:10 PM
My unit has a 3 stepper. One of the step rivets gave way last year in Wisconsin. Replaced the rivet with a 1/4 x 3/4 x 20 stainless steel bolt with a stainless steel nylon lock nut. Last week I discovered another rivet was ready to go. I drilled out all the existing step rivets and replaced them all with stainless steel bolts. I also use a step support under the steps.
Bob
