-   -   Hot water tank (https://www.forestriverforums.com/forums/f110/hot-water-tank-106530.html)
Cardinal camper 04-24-2016 08:54 AM
Hot water tank
Just noticed last nite the pressure valve dripping. Reason for concern?? What might cause this?? Tks!!!
Flybob 04-24-2016 09:00 AM
Open it, let a little water out and let it close again quickly. Some times it can get some crud in it or just not seat properly.
bubbles 04-24-2016 09:01 AM
Sometimes it's because when the release toggle is not allowed to snap back into position after opening after pressurizing the system it might leak a little. Also, some leakage from the valve could be normal as stated in the owners manual I have.
Cardinal camper 04-24-2016 09:02 AM
Tks!!
youroo 04-24-2016 09:02 AM
Only do this when Water is COLD!:thumbsup: Youroo!! :us-flag-waving:
Cardinal camper 04-24-2016 09:03 AM
Tks for your help!!
Ford Idaho 04-24-2016 09:05 AM
Had this issue last year while at Crater Lake, Flybob is correct.
It took 4 quick flips to get it to stop leaking, I used a hand towel to keep the hot water from going every place.
Do be very careful.
Now you tell me.....;)
Cardinal camper 04-24-2016 09:07 AM
Tks!! Will definitely try this!!
