-   -   TV Brake Pads and Rotors....Check Them (https://www.forestriverforums.com/forums/f110/tv-brake-pads-and-rotors-check-them-106556.html)
Forbes 04-24-2016 01:38 PM
We all check our axles on the TT or 5th wheel but how often do you check your TV's brakes pads and rotors, like most when they start making nosy.
I may be over board but I replace my TV brake pads when the RV comes out of storage. Check the rotors to make sure they are not grooved or have rust on them. On most trucks 60% of your braking is done by your front brakes and they go fast. I have even started carrying a set of pads with me, does not take that long to change them and its not hard to do, if you can grease an axle you can change brake pads.
Jim34RL 04-27-2016 04:49 PM
Every 5,000 miles when I rotate my tires. I changed out the front disc brakes at 80,000 miles and the rear brakes at 1000,000 miles.
