-   -   best device or app for height information (https://www.forestriverforums.com/forums/f110/best-device-or-app-for-height-information-107314.html)
judivan 05-03-2016 03:40 PM
I am looking for a way to give me height of bridges and overhangs? I have a trailer that is 13'2". Is there such an app or device that can help me with that and reroute me around the obstacle before I get to it? Please help me if you can.... Thanks for your help in advance.. Van :trink39:
Teamfour 05-03-2016 03:51 PM
Not sure if they have an app, but the truckers almanac give clearance info for routes. There are also downloadable POI files for gps.
clr 05-03-2016 03:59 PM
Their is a app for a GPS called lowclearance that you may be interested in. It will warn you of a low clearance within the distance that you chose. I have mine set at 2 miles. It will flash a warning symbol on your GPS screen where the low clearance, and sound an alarm. It will not auto reroute you around the low clearance.
If you want total type operation such as rerouting or not putting you on any route with a low clearance. Then you are looking a one of the RV or Trucking GPS units.
Davidceder 05-03-2016 04:11 PM
What type of GPS system are you using?
clr 05-03-2016 04:33 PM
I am using a Garmin nuvi 2555 currently with the lowclearance app installed and the proximity alerts turned on.
Davidceder 05-03-2016 05:54 PM
I use low clearances on Streets & trips. I find it to be fairly inclusive. I have a built in NAV so cannot use LC. Are you unhappy with it. Most probably the best if you don't want to go commercial.
clr 05-03-2016 10:13 PM
I have been happy with low clearance and it has worked well for us. The only limitation I have found is that it went off on I74 near Morton Il and at first the alarm was going off and the GPS display was not showing where the low clearance was until I got closer. Then the warning was right on the interstate but I could see there was no overpass. The low clearance was right under the interstate one lesson learned.
Davidceder 05-03-2016 10:30 PM
FYI;
I got an e-mail last week that LC has a big update you can download. Until you find something else you might want to make sure you have the latest. You can download it off the membership page on their site.
gectisme 05-03-2016 10:37 PM
If you have a smart phone check out the CoPilot GPS App. You can enter in your height and it will route you around obstacles.
:signhavefun:
flymhi 05-03-2016 10:53 PM
S&T is no longer supported or updated by Microsoft so the data is aging out.
The Allstays app has low bridges bridges noted. Check this thread
Davidceder 05-04-2016 10:23 AM
I know that but still a good program and it is all I have that supports LC. I looked at the other programs but not as good as S&Ts. As I said, I look at all this when we lay the route out, so I can see the entire trip on the PC. So there are two issues here, 1) Laying out a route and 2) real time on an in vehicle GPS. Don't feel like having a aftermarket GPS when I have on in the car. We look at each days route on S&Ts for LC's and take it from there. There really is not any good "Routing" programs out there so S&T's is the best for me. An additional issues is I am at 13'6", the legal limit. Sorry I had the front AC installed. We are just very careful about where we go and ask parks if there is anything we need to worry about on the way in. Nothing is perfect. I might try Mapsource as a replacement for S&T's. MY worst nightmare is being on a two lane, coming up to a LC and not being able to turn around. What does one do?
denville 05-04-2016 11:50 AM
I use low clearence POI. You load it onto your GPS and set the hight you want to be warned at. You also set the dI stance from the low clearence you want to be warned. I have mine set a 2 miles. It will not reroute you just warn you there is a low clearence in 2 miles. It will warn you even if the low clearence is not on the road your on but you are within 2 mikes of it. Would be nice if GPS navigation would re route you automatically
ben31 05-04-2016 03:35 PM
Truckers almanac is a good physical planning tool. I have a Garmin 760LM (rv gps), which uses the information you put in to help avoid problems. No GPS will guarantee to avoid all obstacles, so you still need to watch for warning signs, but using these two items, I have never had a problem. Smart Truck Route is an excellent Smartphone based gps app, also. If you run diesel fuel, it will also show you the truck stops along the way.
Davidceder 05-04-2016 04:23 PM
Thanks Ben;
Wish I could overlay LC's in my F-350 GPS system.
kjpapa 05-04-2016 04:36 PM
Allstays Camp and RV has low clearances noted. I use it for almost everything -- finding campgrounds, truck stops, rest areas, Walmarts, etc. Quite frankly though I have had more trouble with untrimmed trees on minor highways than I have had with overpasses, and no one offers that data. If you are taller than a UPS truck and are on a road that does not have regular semi-trailer traffic you have to constantly watch.
Filterman 05-04-2016 05:52 PM
I have the Rand McNally 7715 and it routes you according to the parameters you put in it. Include your outside RV height and it will make sure you stay away from routes that are low clearance. Anywhere that is marked as a truck route should give you 13'6" minimum height but you need to watch the side gussets on steel girder bridges because some of the narrow ones on secondary roads may be lower clearance on the outside edges. rM also make a downloadable software version now if you want to use it on your IPad. I have not used it so can't vouch for its performance.
camaraderie 05-04-2016 08:01 PM
:signhavefun:
X2...and it is cheap and lets you download maps to your phone so you aren't eating your data plan up as you drive.
Davidceder 05-04-2016 08:23 PM
Co-Pilot stuff looks interesting. Are you using the Truck or Auto App?
camaraderie 05-04-2016 08:54 PM
Using the auto app which does let you set height limits. They also have an RV app for $50 bucks which I didn't think I needed since I already have a Garmin RV GPS with lots of RV related options.
Scheinin 05-04-2016 09:39 PM
Height
I use the Garman 760 RV. I put in the stats of my 5th wheel and it routes me so I don't hit anything. However, it does not tell me of propane restrictions, like some tunnels.
