-   -   Command center wiring schematic? (https://www.forestriverforums.com/forums/f217/command-center-wiring-schematic-139399.html)
kenandterry 07-15-2017 03:27 PM
Command center control panels are different depending on whether you have electric and propane water heaters, Arctic Pac equipped or not, water pump switch, and number of slides if equipped.
Is there a wiring schematic for wire colours of the switches and indicator lights for fresh, grey, black, battery, LPG?
Seems most of the time, FR uses white wires for ground (-) but not always?
