-   Cardinal (https://www.forestriverforums.com/forums/f22/)
-   -   2012 3450 RL wheel bearing seals pn# (https://www.forestriverforums.com/forums/f22/2012-3450-rl-wheel-bearing-seals-pn-143743.html)
LCWarden 09-05-2017 10:54 AM
Does anyone know what the part number is for the wheel bearing seals on my 2013/13 cardinal 3450RL with 7000# axles and 235/80/ R16 tires and stock aluminum 8 lug rims? I can cross reference just about any part number...thanks...Lee
djousma 09-07-2017 09:03 AM
If you know which axle's are on your Cardinal, you should be able to go to Dexter's website for that info.
LCWarden 09-13-2017 07:32 PM
Dexter part # Fits Dexter 12 x 2" hub, 2.250 ID x 3.376 OD (after 1998)
010-036-00
CMelder 09-19-2017 10:21 AM
My 2012 Cardinal 3675RT has Lippert (LCI) Axles for sure. The LCI tag is on the rear side of the axle tube. I also understand the Dexter axle numbers are stamped in the tube in a similar location.
If you get the axle brand, model, serial no. you can contact eTrailers or most other supply houses and get the proper parts.
