-   -   Tire question (https://www.forestriverforums.com/forums/f15/tire-question-157872.html)
johnlantz 04-20-2018 05:02 PM
Tire question
I noticed cracks in the sidewalls while doing my spring cleaning. My question are these just cosmetic or an indication the tires need to be replaced. I see it on all the tires. The tires are 4 1/2 years old, about 20k miles. I know you typically replace tires on rvís before all of the tread is gone. But 4+ years seems short. The tires are not covered in the winter.
Trying to attach pictures...
johnlantz 04-20-2018 05:04 PM
2 Attachment(s)
Here are picsAttachment 168978Attachment 168979
HangDiver 04-20-2018 05:05 PM
I would replace them.
RedLdr1 04-20-2018 05:16 PM
I'd replace those as well... I've always been told that "RV tires generally don't wear out, they time out" and that five years was the replacement schedule for tires.
geeman53 04-20-2018 07:03 PM
Replace.
Rdeejr 04-20-2018 07:18 PM
Definitelyyyyyy. Replaceeeeee.
Duckogram 04-20-2018 08:43 PM
The pictured tires are unsafe. 5-10 years are max exactly because of the condition shown. 10 years is rare and only attained with meticulous care.
Iwannacamp 04-20-2018 10:52 PM
Michelin had some issues. I would check with a reputable dealer about possible recall. Ymmv
rsdata 04-20-2018 11:15 PM
X2 KEEP THEM COVERED when not in use... occasionally spray with 303 to add a year or two...
babock 04-20-2018 11:17 PM
What is the date code on the tires?
russhd1997 04-21-2018 05:32 AM
The date code is the 4 digit code at the end of the tire serial number. The first two digits are the week that they were manufactured and the second two are the year. For example a date code of 1313 would mean that the tire was manufactured in the 13th week of 2013. More than likely the tires are a year or two older than the 4.5 years that you've had them.
johnlantz 04-23-2018 08:50 PM
0513. So they are less than 5 years old. Looked at my tire warranty and Michelin says you should get 6 years out of a tire. I got a claim with Michelin will get the tires inspected to see if they should be replaced. Maybe they will give me something towards a new set. Not sure if I would want to buy another set of Michelinís though.
gectisme 04-23-2018 08:58 PM
I had the same cracking on the truck OEM Michelins in 2015 on our 2010 Dodge. I can't find the paperwork but Michelin gave us somewhere around $150 a tire so you will definitely get something from them. They know those tires had issues.
:signhavefun:
Iwannacamp 04-23-2018 09:31 PM
:signhavefun:
Mmmmhmmm. Seen too many times
babock 04-24-2018 09:55 AM
0513 means they are older then 5 years old. If they were mine, they would have already been replaced.
5picker 04-24-2018 10:01 AM
0513. So they are less than 5 years old. Looked at my tire warranty and Michelin says you should get 6 years out of a tire. I got a claim with Michelin will get the tires inspected to see if they should be replaced. Maybe they will give me something towards a new set. Not sure if I would want to buy another set of Michelin’s though.
0513 designates a manufacture date of week 1 in Feburary 2013.
EDIT: deleted incorrect information.
andymil 04-24-2018 10:09 AM
0513 means they were manufactured January or February of 2013. Fifth week.
5picker 04-24-2018 10:12 AM
You are absolutely correct.
My apologies for jumping in without a clear head.
Mods, I'm going to edit my post.
andymil 04-24-2018 10:17 AM
No problem. Easy mistake to make.
JohnD10 04-24-2018 10:33 AM
These tires are so close to the five year mark...
Isn't that kinda' like eating all of a Quarter Pounder w/cheeze down to the last bite, then taking it to the counter and telling them something is wrong with it?
:confused:
Edited...if those tires are code dated 0513, that means they are over five years old as that puts them at the first week of February, 2013.
