-   -   One of the fixes for Slide outs not working (https://www.forestriverforums.com/forums/f88/one-of-the-fixes-for-slide-outs-not-working-164235.html)
pokey 07-03-2018 05:46 AM
I was having a problem with my slide outs not working awhile back and thought I would share the fix (for mine) and hopefully help others with the same issue. After getting advise from this very helpful forum, contacting Lippert Tech support I finally found the very minor issue. It was not a fuse, battery, a reset switch that Lippert said that I had and don't it was a little bit loose hot wire on the buspar coming off the solenoid attached to the motor. It was slightly stripped so I couldn't get it to tighten and wouldn't remove to replace. Finally I just attached an Alligator clip to the wire end and bolt head and everything is working great. Just something to check if anyone is having the same problem with their slide outs. :signhavefun:
