-   -   Awning over slide (https://www.forestriverforums.com/forums/f232/awning-over-slide-167276.html)
colourful64 08-04-2018 06:36 PM
Awning over slide
Hey we have awnings over the slides and they are sagging is there a way to tighten them up
FordHauler 08-04-2018 07:02 PM
Go to the “Library” tab at the top of the page. A search there will yield many answers!
Travel safe
colourful64 08-04-2018 08:55 PM
Travel safe
I don’t see “library” and I have searched within and can’t find it
NMWildcat 08-04-2018 08:57 PM
It's on the website, not the app.
colourful64 08-04-2018 09:17 PM
I went to the desktop and still can’t find the library. I did a search and there is nothing for my problem
Scrapper 08-04-2018 09:23 PM
Light green bar at the top of each page under the page header. The bar contains Portal, User CP, Library, etc.
Are you asking about Slide Topper that extends when the slide is deployed or actual awnings with arms that you have to push a button to deploy?
DutchRv 08-04-2018 09:32 PM
FR3's have slide toppers. Found some stuff in the library on those...
DutchRv 08-04-2018 09:46 PM
I believe FR3 has Solera (Lippert) slide toppers. Torsion spring should be able to be adjusted/rewind.
Lippert has excellent techs on LCI1.COM you can chat with during business hours...
colourful64 08-05-2018 12:21 AM
Thank you so much. I was talking about he toppers
Orider 08-05-2018 07:43 AM
I just finished packing my 32DS and noticed that the dinette slide topper was flapping in the breeze. I had just read the problem you had "colourful64", so I tried something. When I was loading, I DID NOT extend the slides all the way out. I just wanted enough room to get under the sink and behind the TV. I extended the slide again and let it go out an extra 1-2 seconds, then retracted it and let it run for another 1-2 seconds. WOW it is not tight as it should be. Maybe try this..
