-   -   Jacks won't retract (https://www.forestriverforums.com/forums/f232/jacks-wont-retract-167966.html)
Dylvinia 08-13-2018 04:38 PM
Jacks won't retract
Tried everything including manual override with a drill and socket.
HELP!!!!
2015 FR3
edm 08-13-2018 04:57 PM
Have you checked the 100 amp circuit breaker on the right side above the batteries? The breaker has a red flag sticking out if it is tripped , if it is tripped just push the flag back down to reset.
Good luck.
formerFR 08-13-2018 04:59 PM
you blew/tripped a Main BUS fuse/breaker, probably in the battery bay, on the wall, may have a little red or yellow flag protruding, push it back in.
Dylvinia 08-13-2018 05:18 PM
Solved!
After being very annoyed and almost giving up I retraced my steps tapped everything with my maglite and double checked all connections and fuses and when I had pushed the red flag fuse in the battery Bay in apparently I hadn't pushed it in far enough because I hit it again and it clicked and boom everything worked perfectly. Thanks so much for your replies guys appreciate it and learning more about my RV every day lol
Our circumnavigation of the nation over the next few months continues!!!
Dylvinia
