-   -   Fire place heat doesn't work (https://www.forestriverforums.com/forums/f113/fire-place-heat-doesnt-work-171407.html)
Wallyandlisa 09-30-2018 04:30 PM
I have a 2019 cedar creek Hathaway edition the heat on the fire place keeps telling me error code E3 which means it's over heating any one else had this problem
Bama Rambler 10-02-2018 12:51 PM
Does it show up as soon as you start it or after it's been on a while?
Can you hear the blower running when you start it?
Mr Towed 10-02-2018 01:11 PM
I know nothing about this trailer, however, some people will recall a recent post about someone who said their microwave wouldn't work. It turned out there was a hidden switch to essentially choose between using the microwave or the fireplace. There was nothing in their manual about this and they had not been told about it at delivery, only other forum users knew about it; maybe this is your problem. I hope it's something that simple and the switch, if it exists, is easy to find.
Wallyandlisa 10-12-2018 08:56 AM
Well turns out that the fire place is mounted to a drawer that pulls out to reveal a hidden compartment and when they mounted it they didn't check to make sure the fan inlet was open to get flow notched the drawer fan blows harder and the trouble code stays off works fine thanks for the input guys
Mr. Dan 10-12-2018 08:59 AM
Thanks for reporting back with your solution.
