-   -   V Shape TV Mount (https://www.forestriverforums.com/forums/f113/v-shape-tv-mount-171664.html)
Jeff from Burlington Ont 10-04-2018 02:37 PM
V Shape TV Mount
I am looking for the manufacturer of the TV mounts in my Wildewood Heritage Glen. There are 3 mounts and no manufacturer stamp that I can see.
The TV side has a plate with a corresponding V that slips into the slot. The mounts inside the camper are on arms, so they can be swiveled. All TV mounts are interchangeable which is handy
I would like to buy a mount to put in my garage so I can use the TV when not camping
Thanks Jeff
rmac04401 10-04-2018 02:41 PM
PAW international. They are sold on amazon.
https://www.amazon.com/PAW-Internati...ds=rv+tv+mount
jd50i 10-04-2018 03:04 PM
https://www.amazon.com/PAW-Internati.../dp/B01GTYXEDU
TheWolfPaq82 10-04-2018 03:23 PM
Thanks Jeff
Just a note...the hole pattern on them only match that of computer monitor...at least from my experience. Had to modify mine to hang a small flat screen in our Cherokee.
bikendan 10-04-2018 05:02 PM
If it's metal, it's NOT a PAW International mount.
My PT TracerAir has the metal ones and the plastic PAW mounts won't work, unless you shave some off the edges.
rmac04401 10-04-2018 09:00 PM
They make metal one also
Attachment 188265
bikendan 10-04-2018 09:08 PM
Attachment 188265
A year ago, when I talked to the owner of PAW, they only had plastic mounts. So they must be a recent addition to their line.
5picker 10-04-2018 09:35 PM
PAW told me their metal brackets are narrower and don't fit the factory brackets. I did find some factory type metal brackets a couple years ago for forum member Turbs but I can't seem to find that old post.
I think forum member Old Coot made a bracket by welding a couple small pieces of angle to a metal plate.
BigRockr 10-05-2018 08:04 PM
Don't you get a pair, one for wall and one for TV in the pack?
5picker 10-05-2018 08:36 PM
Yes, but the OP wanted to take their tv (with one half of the factory bracket already installed on it) into their garage when not camping. They were looking for another half like that mounted to the camper.
Wolverine 1945 10-06-2018 05:15 AM
Attachment 188265
$43 NO CRAP ???
:crying::crying::crying:
Lektrikon 01-03-2019 11:37 AM
TV V Mount weight limit?
Does anyone know what the weight limit is on the factory provided tv mount? I had a 32 inch tv weighing about 9 pounds but I want to upgrade to something like a 40 inch weighing closer to 14 pounds.
D W 01-03-2019 12:29 PM
PAW advertises that all three mounts 100x100, 200x100 and 200x200 are rated at 30 lbs max.
