-   -   Max air ghost? (https://www.forestriverforums.com/forums/f113/max-air-ghost-172230.html)
Fredski007 10-13-2018 09:18 AM
Max air ghost?
6 am Saturday morning the max air fan started in the rear bath in our dx3. The only way to shut it off was to pull the fuse at the main fuse panel. Try finding the right one at 6 am! Anyway pulling the fuse shut it off and reinstalling it closed it automatically. Now nothing works. I can manually open it but no fan power. Any ideas?
katkt 10-13-2018 09:23 AM
My bath fan is connected to one of the light switches. If you want the fan to run, and the lid is up and switch is set to a speed, you have to turn the light switch on.
Of course, mine are manually operated. Since you have an automatic gizmo of sorts, it may not be this simple.
Fredski007 10-13-2018 10:27 AM
Nope, this on its own circuit (12volt) not connected to a light. Max air is closed on Saturdays !
