-   -   Winegard Carryout G3 portable satalite (https://www.forestriverforums.com/forums/f113/winegard-carryout-g3-portable-satalite-173282.html)
Bayouownbeer 10-28-2018 11:24 PM
Will one of these domes hook up to the cable input and supply satalite signal to any TV in the coach just put the receiver on the corresponding tv?
RVBill 11-09-2018 09:04 PM
Iím doubt it,I had three new units and always had to have a direct connection from satellite to receiver , just run it through your slide or have new connection installed
GOTTOYS 11-09-2018 10:08 PM
Buy a small signal generator to trace the wires. I got one at Home Depot for around $15.00. Has saved me a lot of headaches.
flhtci2006 11-09-2018 10:25 PM
What I did: Plug G2 into sat/cable connector on RV. Connect sat/cable connector inside theRV to the G2 cpower insweter then the small cable from the inserter to the receiver. Your receiver should have an HDMI, composite and component outputs. I have the hdmi go to my living room tv. I have the composite go to a RCA to coax converter https://www.amazon.com/CIMPLE-CO-Com.../dp/B06XC9Y3VB
That coax tv output goes to a signal splitter. The signal splitter attaches to the coax cable that goes to my bedroom tv and one to the outside tv. When I select the receivers HDMI output, I get living room tv. When I select the receivers composite output, I get either the bedroom or outside tv (which is actually the tv from the bedroom moved outside).
spock123 11-11-2018 08:53 AM
I got a a person that installs tvís to trace mine down. Amish donít have a tv or electronics in there houses
nomad297 11-11-2018 09:06 AM
Some do and some donít. Theyíre not all as quaint as most tourists like to imagine.
Bruce
ousooner 11-11-2018 09:06 AM
Our 2019 Flagstaff has a cable connector and a satellite connector side by side.
Thurman 11-11-2018 10:23 AM
GOTTOYS: Please share info on the "signal generator", such as SKU#, you purchased. I did a "Home Depot" search and did not find this item. Thanks
