-   -   Dometic Brisk Air II A/C (https://www.forestriverforums.com/forums/f113/dometic-brisk-air-ii-a-c-173859.html)
PKC1740 11-07-2018 12:08 PM
My Dometic Brisk Air II 15k BTU mounted on my 2018 Vengeance 25v, seems to be leaking compressor oil on my roof. I brought the unit in to my local dealer to have it checked and they kept it for two months with it plugged in and the AC turned on. I was told that that there was nothing wrong with the AC because it would have stopped working by now if there was a leak. They claim the dark black lines from the AC is condensation mixing with dirt on the roof. The problem I have with this is that the rest of the roof is spotless. It is cleaned after every use, parked under a roof and covered. I scrubbed the area, which is really bad since being ran for two months, for hours with a medium brush and Dawn and it is not as dark as it was but still a noticeable stain. If this is oil, I know I will have roof problems at some point.
I filled out a contact form on the Dometic website and even attached pictures two weeks ago and I have yet to hear anything from them.
I read online of other incidents with Dometic 15k units having this problem. Anyone else experiencing this problem?
Attachment 190888
Bama Rambler 11-07-2018 01:25 PM
Maybe it's the picture, but that doesn't really look like oil. I have to agree that if it was compressor oil, your A/C would have quit by now.
Have you taken the shroud off the A/C to see if you could pin point where it's coming from?
Take some Awesome cleaner and spray on a rag and rub on it. See if that cleans it off.
Thurman 11-08-2018 12:34 AM
I will also say to remove the A/C shroud to inspect everything under the shroud. You may find that there are leaves in the bottom of the drain pan. IF so--the condensate that builds up within the pan will wet the leaves and tannic acid will be the result. Tannic acid is a brown color and that could be what is staining the roof.
