-   -   Dash, miles to empty... off? (https://www.forestriverforums.com/forums/f232/dash-miles-to-empty-off-175491.html)
str8edg 12-07-2018 04:18 PM
Our 1st RV and we have about 1500 miles on or 2018 FR3 DS32.
On the instrument panel i do like to use the miles to empty text that is provided by Ford. I know i have an 80 gallon tank. But even after filling it only reads 180 and then after i get past the halfway point it seems at some time add more miles to the reading, just seems weird to me... is this normal?
Any explanations?
TIA
TLAK 12-07-2018 08:09 PM
Not normal, mine will read around 500 when the tank is full.
leisurelarry 12-08-2018 01:39 AM
2015 30DS, depending on my most recent average mph at fill-up, my miles to empty will show 560 (7MPG) occasionally up to 640 (8MPG).
OldGunny 12-08-2018 09:30 AM
HA!
I never knew we had that on our coaches!
Cover Dog 12-08-2018 07:09 PM
Just like a car I once had, if you didn’t turn the car off when fueling the gauge moved very slowly. Once the car was turned off “miles til empty” jumped to where it should be.
Is your ignition turned off when fueling ? That would be my only guess.
yensidcamper 12-08-2018 09:24 PM
Mine usually reads between 580 and 620 after fill up.
str8edg 12-12-2018 04:21 PM
So weird... maybe i need to see if i can change settings or something... Thanks Gang!
clarkbre 12-12-2018 08:14 PM
I responded to your other thread and thought of something else.
It's too soon for an accurate calculation. With an 80 gallon fuel tank and only 1500 miles, the computer likely doesn't have enough data to calculate an accurate Miles to Empty guesstimate.
I can speak to this as my old '11 F150 would never be accurate as we towed our trailer and a couple tanks thereafter. It would usually take running 500+ miles without towing the trailer for the truck to have enough data to calculate an accurate MTE.
I know if your case, this is a motor home; however, if it is just out of the break in period and you haven't done many consistent highway miles, the MTE calculation will read very conservative.
Just my $0.02.
str8edg 12-12-2018 09:23 PM
The rig does have about 3,300 miles... we bought it with the 1300 or so miles used to drive it from Forest River to South West Florida.
Frameman 12-15-2018 06:43 AM
Try dIsconnecting engine battery for a few minutes! It should reset computer. Give you a more accurate reading .
Frameman 01-05-2019 08:25 AM
Try disconnecting engine battery for about ten minutes and reconnect. It will reset the computer should change your miles to empty.as you drive it will compute to your to your driving style and give you a more accurate reading .
