-   -   MORryde Steps (https://www.forestriverforums.com/forums/f23/morryde-steps-177515.html)
2rad4u 01-23-2019 06:03 PM
I laugh every time I read these posts. These steps COULD NOT be easier to deploy, easier to clean, easier to fold, easier to adjust, easier to use and more solid if they tried.
And yet, people have to come on here to bash and complain about them.
You bought them, or bought an RV with them. It's nobody's fault but yours.
spock123 01-23-2019 06:10 PM
I have a friend that swears by them just not for us. A lot of people love them. Cedar Creek installs then on new campers. Sometimes the factory will let you option in the old steps. A lot of people like the new Cedar Creek Hathaway that doesnít have the rear cap, not us. Different people like different stuff on campers, if it works for you I say great
waybeck2018 01-23-2019 06:50 PM
The DW loves these due to her vertigo and lack of leg strength. She really likes the stability it provides. Yes, a pain now and then to deploy but overall we are pleased with them.
Boomerweps 01-23-2019 08:29 PM
While I mentioned problems I encountered for others to avoid, these very stable steps were one of the selling points on the TT I selected. I did have to carpet them for my dog to use them.
MikeRP 01-23-2019 08:41 PM
You are right opinions vary! And we all know there is pluses and minuses to everything. Iím glad I read this thread, I didnít have on my list to deploy these properly.
Rdeejr 01-23-2019 09:37 PM
I really like mine but am having issues with the strp threshold rubbing on bottom of the door even with them fully adjusted in. This makes the steps lean downward.
Iím gonna try the driving on boards and see if that helps.
ba964 01-23-2019 10:11 PM
2rad4u said it all.
Jayhawker 01-23-2019 10:41 PM
MORyde steps
Originally Posted by ba964 (Post 2011146)
2rad4u said it all.
Totally agree!:trink39:
Jeeptchr 01-23-2019 11:22 PM
I added them to our camper and love them 95% of the time. I was having this same issue and have figured out once I level the steps if they are rubbing the door like you describe (I trimmed the screen door so I donít have an issue there) I will stand on the top step and jump a couple of times and that usually sets the step threshold perfectly. Itís heavy enough gauge metal I donít see metal fatigue setting in for a long time.
ependydad 01-24-2019 12:21 AM
Itís not about fault, itís about pros and cons to a product. By your logic, no one should complain about anything ever. That would make for a boring forum!
No product is perfect. Why not discuss the disadvantages and talk about possible solutions?
Jim in Florida 01-24-2019 03:28 AM
I have had an issue once in the storage lot with needing to get inside to reset our leveling system. We were fortunate that there was clearance between our neighboring trailer, so we had room to fold down the steps. I was concerned of what we would do if we did no have enough clearance. Contacting MORryde was no help.
I decided to drill out the rivets holding the leg assembly onto the pivot and replace them with clevis pins. Now, if if ever need access to the trailer when I am unable to fold them down I will be able to remove the pins and take off the steps temporarily.
I have not had any issues with being parked to close since!
Jim
Mch5jdm 01-24-2019 06:33 AM
I too have that issue. I am on boards and not much help. I think I am going to remove the door sweep to see if it helps. Other than that I like. My rig has 2 entry with a standard step on it. Makes potty breaks easy while enroute.
rjshiflet 01-24-2019 06:44 AM
Got to say...we LOVE ours. We keep a small "whisk broom" in the side compartment of the trailer for a quick sweep before folding them in. We are in our fifth wheel at least 8 days each month year-round and we've been fortunate not to have to pack up in rain. I can imagine that would be problematic with water on the steps being folded in.
But, all in all, much safer and much more stable in my opinion.
2rad4u 01-24-2019 06:54 AM
Small hand towel.
Lift steps, shake a little to drop any standing water, lower steps, wipe with towel, fold up, lay towel inside door (under steps) to catch any residual dripping. Easy
This also "cleans" the steps so your killing two birds with one stone. ;)
Also, I made sure my awning covered both entrances so not getting wet while camping is a plus.
Fundy 01-24-2019 07:22 AM
We love our steps, I originally used a "whisk broom" until I was using my cordless leaf blower an thought why not use it to blow off the steps.
It is a small blower I remove the "tube" and use just the blower itself, fits in a small compartment next to the steps. It will blow off any loose dirt along with any water on the steps, if you reinstall the "tube" you can use it to blow loose dirt off your camping mat :D
dalspot 01-24-2019 08:00 AM
Originally Posted by ependydad (Post 2010163)
Y'all are making me love my Glowstep Revolution steps by Torklift with each post. :D Sorry to George & Nancy for the issues you had and the bent door. That sucks!
X5
They are expensive, but we got a good deal on Black Friday.
TheWolfPaq82 01-24-2019 08:05 AM
Did the same and wrapped each step with the strap on tread covers. had to mod the one for the top step, but when they get really dirty I just take them off and hose em down.
Boomerweps 01-24-2019 10:55 AM
I'm not sure of your issue. These steps need to effectively be hanging from the top hinge so the top hinge lays flat on the threshold. Then extend the feet. Granted you do not want to literally be hanging all that weight on the hinge. If the hinged section sticks up even a little bit, it will interfere with the door opening.
2rad4u 01-24-2019 12:56 PM
It seems easy enough...
rocco52 01-24-2019 03:53 PM
I actually like them very much but had not thought of the access while in storage issue. I will add that after one month one of the bolts to the shocks supporting the weight sheared making it very heavy to lift and a little dangerous to lower. I was surprised that there was that much stress on a 1/2" bolt.
