-   -   Brake lights not working (https://www.forestriverforums.com/forums/f218/brake-lights-not-working-182264.html)
RollinWithTheTumbleweed 04-07-2019 11:00 PM
Hi everyone,
I have a 2007 Georgetown class A gas model in the ford v10 chassis.
Today I was following my husband in our road (crazy mountain pass so we chose to drive separate) and I saw his brake lights were not working.
The hazard lights are working and so are the turn signals and running lights.
Going to check fuses tomorrow... anyone know what number fuse we’re looking for under the steering wheel or under the hood?
Thanks in advance!
Bama Rambler 04-09-2019 09:26 AM
If you haven't found it yet, you can find wiring schematics on the Ford upfitter site.
It could also be the pedal switch. It's located on the side of the brake pedal arm under the dash.
RollinWithTheTumbleweed 04-09-2019 12:20 PM
All fixed!
Thank you, yes it was the control switch for the gas pedal- it had came loose. I used tape to keep it on straight so it works properly.
Bama Rambler 04-09-2019 12:26 PM
Thanks for coming back and letting us know what you found.
