-   -   Furrion fireplace insert (https://www.forestriverforums.com/forums/f2/furrion-fireplace-insert-197946.html)
marknelson 11-15-2019 04:33 PM
My Furrion 26" insert isn't working at all. :(
I can get the heat going for about 30 seconds and then it shuts down?
Of course not on warranty. Any ideas on how to repair it?
Or maybe any ideas on where to purchase a 26" fireplace insert?
hshaynes 11-15-2019 09:22 PM
Do you have anything within about 12 inches on front of it? I had a similar issue until I moved a bag that was less than a foot away and to the side.
Oaklevel 11-15-2019 09:43 PM
You should have a manual, it should include an address and phone number. I had to call them once they were a great help.
:signhavefun:
Witch Doctor 11-15-2019 09:56 PM
Had the same problem it came out to be the board , there are 2 of them inside, itís best to just replace it. Any 26 ď one will work, just google it, they have them from about 150 bucks, they just plug in. It would almost cost the same for the boards, I think they even have them on Amazon, the boards are garbage, just replace it.
Witch Doctor 11-15-2019 09:59 PM
Here is oneAttachment 219240
quicky06 11-16-2019 02:15 PM
Mine does the same thing but only when heat is on high. If I keep it on low it does not have any issues. It’s on my todo list to pull it out and tear it apart but I don’t use it if it’s below freezing and when I don’t have shore power which means I have until spring to get it figured out.
