I get confused sometimes between doubling of energy vs. doubling of voltage and have to review it occasionally. I'm currently just a part time sound man. There are a few free decibel meter apps for your phone that I find handy. This spring I plan on sound testing my three generators and will move the meter to a distance that duplicates the listed dB spec. I'm done. |
Thanks for getting the decibels correct. 3 dB is twice the energy but our perception is not the same thing. Further, the frequencies also impact the perceived sound intensity. Of course, age plays a role as well along with just how hard the generator(s) work.
FWIW I use a pair of 2000 Hondas when I want AC; 1`for the rest of the time and they are noticeably quieter than Yamahas and others I've heard. |
Champion Generators
Do it its a good deal - light weight to handle 1 at the time . Had a large
Champion that worked really well just really heavy . Champion very reliable but a bit noisy - but if all in a Campground have no power who cares fine for boondocking |
Costco has a Firman 3200/2900 Watt generator with 30A outlet for $500 after $140 discount. Seems like a great price.
I love my champion !!!
I have the Champion 3400 watt and it is a good unit. My only issue is that it is very heavy and it's getting harder to lift into the truck every year. I would certainly go for the two lighter units with a parallel kit if I didn't have this one.
I bought the Champion genie and very happy with it. Quiet and starts first pull..
Before you spring for the Harbor Freight genie - better check the warranty period. As I recall, it was only 90 days. Of course you can purchase an upgraded warranty to get a full year, but you better be adding that into the price of the genie in order to properly weigh it against the others... |
champion
I Have the RV READY Champion .:trink39: i bought it just for my camper BUT But .. IT'S A BEAR TO get it in and out of the truck ..:signhavefun: iv been watching these at tractor supply ... and watching for revuies .. befor i pul the trigger BUT THAT IS A GOOD PRICE :trink39::signhavefun::campfire: |
You get what you pay for
I had a champion generator that lasted until a month after the warranty was up. It needed so much work, it was totaled. I then splurged and bought a Honda 2000. The Honda is MUCH quieter, easier to start, and so far has lasted 4 years of heavy use
I've had a Champion 3500 dual fuel for almost two years and have dragged it around a fair amount. I'm quite happy with it. It is quiet, but the comparable "Predator", despite the name, is noticeably quieter. I have a friend who has had one for two years for his towable and uses it continuously when on the road. Says he has had no problems.
Please stop confusing me!
OK, for starters, I don't have the money for any red units.
I have a Generac iX 2000 (2,200 starting, 2,000 running - so it's slightly more powerful than the red or blue ones of that era) that we purchased when we had a C-class with an on-board Onan 4Kw so we could run the little one for the tv, radio, etc. and just use the big Onan for the air conditioner and micro wave. The problem is that the Generac won't run the a/c on the new 5th wheel, so I need something larger and this one isn't parallel capable (it's 7 years old - never had a problem other than the primer bulb cracking - we're in AZ and the heat is brutal on plastic stuff). I settled on a Predator 3500 or whatever it is - but then I read horror stories about their customer service unless you buy an extended warranty. So based on price COMBINED with customer service I switched over to Champion. (keep in mind I'm looking only at invertors and a minimum of 3Kw). Then I read about the weight of the larger units, and for our needs, we only need to run the a/c a few trip per year, so I considered two smaller units running in parallel Then I found a pair of Yamahas for sale on CL for $700 by the time I called they were gone. DARN! Then I read about double the oil changes (not a big deal) and double the gas something to consider, but again, only for a few trip per year, not a big deal. Then I read a lot of good things about the newer Predators. WTH? I wish one or two would go out of business - it would make my decision easier. Then I find this thread UGH!!!!! I think I'm back to leaning on Champion or maybe Predator or maybe holding off until I find something on CL or eBay (Please note that since I can't really afford Hondas, solar is NOT an option, so please don't go there). Does anyone know how to build a treadmill or hamster wheel that the dogs can run on to make power? It would be quieter than a Honda, use less fuel than a propane unit and I already have two, so I could run them side by side in parallel ... |
Fuel injected carb-Lifan
I have a Lifan 4000 EFI peak, 3800 running. The fuel injected carb is the way to go. Honda has a 7000 fuel injected carb gen. Lifan is sold by HDepot, easy return process and extended warranty protection. Lifan also has smaller fule inj gens. I got my Lifan for running in high altitude.
The most important consideration beyond the noise level is ability to get it fixed should it have an issue (bad gas or warranty issue). I almost bought a Predator since they are cheap and seem to be liked by those that own them, but after looking into the ability to get parts/service on a Chinese brand, I decided to not do it. Harbor Freight offers extended returns window, but that is it. Champion generators should be able to get serviced easily, but see how far away you have to go.
Great ginny
I have this unit and the 3500 dual/fuel unit. I bought it from Home Depot on a close out for under $300. (They may have mismarked it) I didnt need it, but The deal was too good to pass up. It is a very good reliable unit that starts first pull. It probably will not run an AC unit even with a hard start, but it will handle everything else. 2 units connected will take care of a 30a TT
Harbot Carburetor for Harbor Freight Chicago Predator 3000 3500 3050 3200 4000 Watts Gasoline Generator with Fuel Filter Gasket https://www.amazon.com/dp/B07HCGH2H3..._9vyoEbVDTDK7A |
I would also look at the 2500 watt Westinghouse, same weight a Yamaha/Honda and as quiet, can be hooked in parallel for very little.... Heck they are all made in China.
Better Deal on Amazon
I've been looking at generators this size with a pure sine wave output. Amazon has two; one with a Yamaha engine for $499 and an identical one, same manufacturer, with a Senci engine for $389. After researching both I discovered that the Senci engine is identical to the Yamaha, parts are interchangeable. Also, both these generators have a 30 amp plug in addition to the 120 volt plug. You might want to look at the i-Power generators I mention here. The $499 model is also available at Costco if you want to eyeball it first. Only real difference is that the $499 model case is blue and the other is red.
