Trip
I would put a couple of gallons of water in the black water tank to start W/ a scoop of something like Happy Camper. Prevents building a "cone" in the tank as stuff drys.
I also suggest stopping at a campsite w/ services every 3 days to refill water, dump and charge batteries.Many of the state parks are requiring you to make reservations on line. The refrigerator uses very little propane, the furnace will use propane up in several days, depending on the weather and size of your propane tanks. The electricity for the furnace fan would be the biggest power drain and concern, especially w/ 1 battery. You only want to bring the battery down to half charge w/o shortening the life of the battery. Enjoy your trip. |
You don't have you don't have to use your toilet exclusively. Along the way use the state rest areas and commercial travel plazas for the call of nature. There will be ice and 20 pound tanks of propane available. Purchase a shower at a truck stop. there will be plenty of restaurants that will deliver it to your vehicle aka the drive-thru. Hope this helps. |
Not sure why you are traveling but with the way things are right now I would be staying home. Truck stops, gas stations and rest areas are going to be a crap shoot for exposure in some parts of the country that are hit the worst.
Why not spend a few bucks at RV Parks with power, water and sewer and your problems are solved.
Do you plan to drive through Colorado on your way? If yes, be cautious of the weather on I-70 through Colorado. It can be winter throughout May in the mountains of Colorado. The chain law can go into effect during spring storms. Does your truck have 4-wheel drive? We drive 2,100 miles from the mountains of Colorado to Boston several times a year and WITHOUT towing a trailer it takes us at least 3 - 3 1/2 days with two drivers. It's a long drive made longer if you run into a spring snow storm. Good luck and safe travels! |
Limiting exposure is certainly a priority. |
I did locate a couple park possibilities in Nebraska just off the interstate. |
Hi, Just another day in Paradise. If you don't want to dump black water, put a trash bag in your toilet and some kitty litter and you can through it in the trash can. Might want to drop down to I-70 for better weather. 85 in Missouri today....
Fred |
If you choose to use ice in the fridge put it into large zip lock bags. We do this when we set out to take out the trailer as it is in storage. It works well and is a no mess solution.
I agree with using the fridge on propane and I'd also use the hot water tank since you will be washing your hands a lot. When traveling like you are, I am a fan of MRE's and Mountain House freeze dried foods. Ten minutes from the time you heat or add hot water and the meal is ready. In the case of Mtn House, there's enough for tomorrow too. I take a flat of bottled water in the pickup to complement the 5 - 6 gal I put in the fresh water tank, now that hand washing more often is a must I'd probably double that amount of water in the FW tank. Safe travels and enjoy the trip.
Cross country with travel trailer
Why do so many people think an rv is inoperable unless it is parked in a full service campground? Stevenc, Fill your fresh water tank, turn on your fridge and hit the road. When you want to eat pull over and make lunch. Use the toilet and even take a shower if you want. Your trailer has all the amenities for a reason, use them.
Pretty soon, if you put everything suggested in that thing, you wont' have any room to walk from one end to the other. :roflblack:
I should have known better than to leave such a vague initial post. :rolleyes: |
