-   Exterior Maintenance | Roofs, Sealing, Covers & Vents (https://www.forestriverforums.com/forums/f227/)
-   -   2017 HW276 Roof Failing? (https://www.forestriverforums.com/forums/f227/2017-hw276-roof-failing-208802.html)
darkside_floyd1 06-14-2020 06:57 PM
Need some advice.
I got a hole in my roof. No idea how it happened.
This resulted in some water ruining one of my led ceiling lights.
The plan is to use a 4x4 or 6x6 eternabond patch on the hole.
As I was mulling that over I started to think is the rest of the roof ok? It's dry feeling and looks to be checking. I'm not sure if it's ok or what I should do about it.
Do I need to paint or do something to the roof in general before I put on the patch?
I've tried to add some pictures:
https://imgur.com/CGZvUHnhttps://imgur.com/KmfUiGe
links in case they didn't embed properly.
Thank you for your help.
p.s. Just ordered some PUG's
darkside_floyd1 06-15-2020 07:11 AM
Trying to add pictures to make it easier for folks to help me.
How would you fix the hole? I'm considering eternabond tape.
Is the rest of the roof ok? Feels rough to the tough and I see what looks like tones of little "X" or "+" cracks / checks all over the surface is this normal? What should I do about it?
Thank you for your advice
https://www.forestriverforums.com/fo...cture20718.jpg
https://www.forestriverforums.com/fo...cture20719.jpg
https://www.forestriverforums.com/fo...cture20720.jpg
bikendan 06-15-2020 03:40 PM
Fill hole and Eternabond it.
tom39 06-15-2020 03:56 PM
+1 to this recomendation for repairing hole in roof.
At the bottom right of the 2nd picture it looks like the material has a straight edge like it is a piece of sheet material.
Anyone else notice this?
darkside_floyd1 06-15-2020 04:17 PM
Thank you for the eternabond reassurances.
The sheet goods appearance is just an optical illusion. The caulk color and black edge of the roof just worked out that way. I noticed it myself.
Any tips on the rest of the roof?
GalsofEscape 06-15-2020 04:51 PM
i had a tree branch poke a hole in the roof during a storm, it was the size of a quarter - slapped some eternabond on it and was good to go. was still holding well 5 years later when i traded it.
BDenn 06-16-2020 06:17 PM
Hi, I would use some epoxy putty to fill the hole. Before using Eternabond. Just Eternabonded my major seams on my roof. Was thinking could do the whole roof with it.
