Where do you put your paper towels!
I know this is a bit silly but I really want to mount my paper towel holder to the wall I orderd the Camco paper towel holder and there really is no place to mount it that isn't in the way. The perfect spot would be on one of the walls but you can't securely screw into foam so I need suggestions for other options!
has to have studs in that wall. Look where the overhead cabinet screws are installed
Some designs of Command hooks might help you secure it.
If not.....there’s some “killer strong” 3M brand tape. Check for it at an automotive store or big box store like Lowes or a Home Depot. https://www.3m.com/3M/en_US/bonding-...le-sided-tape/ |
I'll give the double stick tape a try if I can find some that is strong enough, considering I'd be pulling on it all the time I didn't even think of using that. As far as studs go, I haven't tried a stud finder to see if I can detect any but I never really trusted those things that much. I've had this camper for two years now and I'm still trying to get a system down for organization. |
There is a thin layer of wood on the walls. Use a wood screw or drywall screw. Just be gentle on the torque.
I do double stick foam tape and a screw. The tape gives some hold and some cushion. I was testing the location for my paper towel holder with command strips. After a couple trips it started to pull the "wallpaper" off the wall. After that, I use screws... |
3/16" Pop Rivets into the wall board, but they leave holes behind just like screws if you have to remove it for one reason or another.
I like the 3M double stick tape but it is so strong it can peel the vinyl off of the wall board. |
That's a pretty cool idea, I'll have to see where I could clip it inside the camper. |
I have placed a 1/2 inch piece of plywood under the cabinet and screwed large head panhead machine screws in from the inside the cabinet. The screws don't interfere with stuff in the cabinet and the nuts are hidden by the towel holder. Just be sure it's where you want it before drilling the holes.
this works for us, doesn't take up table or wall space, ... out of the way, but handy from either side, ...
We love these. Have them in both the kitchen and bath. No unraveling and the click feature lets you tear off with one hand. Easy to mount to cabinets with the supplied screws, or you could mount to walls with small hollow wall anchor.https://www.bedbathandbeyond.com/sto...-towel-holders
You can try double sided indoor/outdoor tape. You're probably going to mount it in a humid area, so the outdoor tape works best. Using tape along the total surface area gives it a lot more strength. Command strips work for most things, but I'm not sure you could get enough strength without using lot of strips.
Get a stand up paper towel holder put anywhere on you counter. they work great and easy to change out rolls.They make sure you get one with tension on it so you can pull towel out and rip with one hand.
I bought 2 of these, one for kitchen and one for bathroom, 2 rolls of tp fit perfect. Paper towels can now hang where you need them, or move out of the way.
Amazon. |
Paper Towel Holder??
A stand up paper towel holder is what we use, at home and RV'ing. No holes to drill or searching for a good location. Take it with you or move it over when it gets in the way.
cruisin |
I realize that a lot of people just read and reply to the "New Posts" and many don't consider the sub-forum (and I do appreciate the suggestions) but I want to point out that this is for a small A-Frame camper that is short on space. There aren't cabinets on the walls to indicate where wall studs would be (or to mount to the underside) and there is precious little counter space to sit this on top of. I also only have one cabinet drawer under the sink area that would put the roll right in the way of traffic so that option is out.
I may look at some of the 3M VHB tape to mount it to the wall but that stuff isn't cheap and I'm concerned it will just pull off the wall covering. I may also design something I can 3D print that can be riveted to exiting metal (Wall Hinges or window trim). Since everything is Aluminum, Rare Earth magnets are out as well. I'll figure out a solution eventually! I'll be in the camper tonight to work on my storage and organization scheme anyway to we'll see what I come up with. I just thought someone would have come up with a solution already so I didn't have to tax my tiny brain! :) |
2 Attachment(s)
We mounted the below SS towel holder to the underside of the cabinet secured with SS screws and blind nuts. The blind nuts are nearly flush with the cabinet surface once installed. The screws can be cut flush with the top of the blind nuts. The holder was positioned so that a full towel roll nearly touched the wall.
As for this towel holder, we have used them for years at home and on the road. They are stylish, sturdy, the rolls can be changed in seconds and they have a friction feature so the towel roll doesn't unravel when the RV is in motion. One of them has been in use for 15 years. It still looks new and it still works new. https://smile.amazon.com/dp/B002YI65...5&ref=aa_scomp The first picture shows the towel holder in the top left corner. Unfortunately, when the pictures were taken, I didn't have the towel holder in mind. |
And all that's needed is to scroll to the top to see the location. [emoji849] |
