New to Sabre, question
We picked up a 2020 37flh about a month ago. I am trying to figure out if my water heater is gas/electric or just gas. Anyone know for sure? So far I can only get it to work on propane. But when I open the panel to the water heater I can see a thing labeled electric heating element.
There is also an on/off switch on the water heater back panel. Anyone know what that's for? I had hot water with that switch in either position. I came from an open range TT that had individual switches for either gas or electric operation of the water heater. Easier to understand/use....This 5th wheel only has a single on/off swith in the kitchen for the water heater. Thanks for any help/info. |
Need the make and model number of WH.
The switch in the water heater itself is very likely the electric. Share a pic or let us know model number. I have a 2018 Sabre and can turn water heater gas on from inside the camper and can turn the electric element on at the heater itself. I'm fairly certain yours is the same.
I think they put it in that location so its most likely to get turned off before draining. That's important. Hope that helps. |
You are correct, Skip12. I learned during my FLH walkthrough with the dealership the electric switch is on the water heater, not in the coach. Its been the same on Sabre's for the past few years now. Still, wish they'd just put it in the coach with the propane switch where most manufacturers put them, but I made the same mistake thinking it was propane-only WH on my first outing. |
Appreciate the info Skip and GP. I didn't think to grab a pic before I put it into storage yesterday. The manual for the water heater says it's from the SW10D family.
But what you described makes perfect sense. I'll give it a try next time I'm out. |
SW10D family...
SW10DE=propane and electric--switch on the outside, lower left, almost obscured behind the burner tube SW10DEL=propane and electric-switch as above, plus connections for an indoor switch as well. |
Just to share one thing we learn (which might be pretty obvious). When you have the WH switched to electric, you don't need to turn on the water heater switch on the inside unless you want really hot water. We had the water heather switch on the inside turned on and the propane off and the DSI FLT light kept coming on. Obviously the water heater couldn't light without propane, but someone had to explain that to us.
I have one too and I wish it did, but unfortunately no extension. Table is kinda small and tight if you want to seat four adults. Only option I found is to purchase and install a replacement table that includes leaves to extend it. Ones I've found online are expensive (I believe they were anywhere between $400 to $600) so I'm just learning to live with the one that came with it. If anyone out there knows of an alternative table that'll work, please let me know what else is out there. I may just have to build one myself and figure out how to install it on the existing table. |
Thank you! I'll let you know if I come up with anything.
These are the ones
Sorry, I found the links on Canadian Amazon, but they must be available in the US, too. |
I decided to make a table extension and install it myself. Went to Lowes and purchased a pre-cut and sanded piece of plywood that was just about the same dimensions of the table top extension. Also got color matched hinges and longer and larger diameter screws (5/8") that'll fit the hinge screw holes. Lastly, got some espresso satin wood stain with polyurethane in it and a finishing stain brush. Total bill just under $50.
To keep the table extension up when in use, I ordered a pair of metal drop leaf extension supports from Amazon ( https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) for another $18. Total cost of this is a lot less and easier install on the existing table than buying and installing a new table. Thanks for the ideas! |
