-   Coachmen Motorhomes (https://www.forestriverforums.com/forums/f230/)
-   -   Schwintek Controller Board Locations (https://www.forestriverforums.com/forums/f230/schwintek-controller-board-locations-215214.html)
Stendec 08-27-2020 05:06 PM
I have a 2020 Coachmen Leprechaun DS216 with two Schwintek slides, and cannot locate the controller boards in any of the storage compartments. Any ideas where they could have been hidden?
fonzie 08-27-2020 05:28 PM
Maybe this thread will help
https://www.forestriverforums.com/fo...on-191456.html
Stendec 08-27-2020 05:54 PM
Originally Posted by fonzie (Post 2401049)
Thanks, it was a BIG help - managed to find one of them.
jonwisconsin 08-27-2020 09:56 PM
Are you having problems with your slides?
Stendec 08-28-2020 08:18 AM
Actually no, I'm just try to study up and be prepared if I do.
I'm new to RVs and am convinced that I'm 30 seconds away from major issues, just paranoid, I guess.
jonwisconsin 08-28-2020 11:58 AM
k, I have mine for three years and they are ok. If you want to learn what to do if you have problems go to YouTube. There are several good videos there.
KyDan 08-28-2020 12:17 PM
I agree you should know where your control board(s) are. I have needed to override mine a few times. I wonder if it's possible for 1 board to control both slides? If you have 2 boards maybe you can call your dealer and they could tell you where the other one is.
jonwisconsin 08-28-2020 02:20 PM
Yes, I agree it is important to know where the control might be. In my Lep the control is inside one of the storage compartment. As I understand there is one control for both slides, that's how the system works.
Marc G 08-28-2020 03:42 PM
Sildes
I have a 2017 Coachman Concord. Each slide out has it's own controller. They are in 2 different compartments and not easy to see, not to mention work on. Many items are difficult to reach like the low water drains.
Witch Doctor 09-25-2020 07:24 AM
They are always located in a storage area, you need one for every slide, there hard to see and get to but they are there normally located under each slide, there is no way you have 1 to operate two slides that I know of. Call Coachmen, they will tell you where they are located.
