-   -   Circuit Breaker issues (https://www.forestriverforums.com/forums/f218/circuit-breaker-issues-216882.html)
Jaz714 09-19-2020 03:03 PM
Should I hire an electrician?
Iím a newbie. Two electrical outlets in my kitchen and one at my kitchen table do not work. I turned off all circuit breakers and turned them all back on. Electrical outlets still do not work. I removed a #15 fuse from another slot and placed into my kitchen slot, to see if maybe I have a faulty fuse, but electrical outlets still do not work. So now, maybe I have a circuit issue. Not sure where to go from here. I have a newer Impression. Thanks in advance, if anyone has any insight!
Mowgli64 09-19-2020 03:09 PM
Are any of them gfci outlets, check for tripped ones
Jaz714 09-19-2020 03:23 PM
It says it’s GFci protected, but there’s no button to push. I’ll keep looking for one. Good idea, thank you
bikendan 09-19-2020 03:25 PM
Originally Posted by Jaz714 (Post 2416921)
It says itís GFci protected, but thereís no button to push. Iíll keep looking for one. Good idea, thank you
Look for the resettable GFI outlet in the bathroom.
wmtire 09-19-2020 03:26 PM
I’m a newbie. Two electrical outlets in my kitchen and one at my kitchen table do not work. I turned off all circuit breakers and turned them all back on. Electrical outlets still do not work. I removed a #15 fuse from another slot and placed into my kitchen slot, to see if maybe I have a faulty fuse, but electrical outlets still do not work. So now, maybe I have a circuit issue. Not sure where to go from here. I have a newer Impression. Thanks in advance, if anyone has any insight!
Let's start with some basics and see if it helps. RV's will have one or more main GFCI outlets, and then have other outlets daisy-chained/connected downstream of this main GFCI outlet.
If the main GFCI outlet trips, then not only will it not work, but all of the other outlets wired off of it won't either.
Also if the main GFCI outlet has a bad wiring connection, or do the other outlets downstream of it, they may not work. This does happen too.
What you want to do is to locate your main GFCI outlet, as you may have more than one. These main GFCI outlets are usually located near sinks (bathroom or kitchen) and sometimes can be up under neath a counter/cabinet.
You are looking for an outlet that will have a test/reset button on it, and to press the reset button should it be tripped. You must be connected to a form of 120 volt AC power (shore or generator) for the GFCI outlet to be able to reset.
See if this video may help
https://www.youtube.com/watch?v=hhrdPBwADBY
Jaz714 09-19-2020 03:43 PM
Thank You! That was it! The gfci sticker was upside down, so I didn’t read that it was GFcI protected. Found the reset button in the bathroom. A million thank yous for your help.
wmtire 09-19-2020 03:55 PM
Originally Posted by Jaz714 (Post 2416939)
Thank You! That was it! The gfci sticker was upside down, so I didnít read that it was GFcI protected. Found the reset button in the bathroom. A million thank yous for your help.
Excellent, glad you got it solved. And welcome to the forums.
