-   -   Water pump issues (https://www.forestriverforums.com/forums/f217/water-pump-issues-216934.html)
rgklever 09-20-2020 09:47 AM
Water pump issues
Our water pump starts but just a little water comes out then it hisses and stops. One year old 21’ mini lite camper. We’ve always been hooked up to water and just found this issue.
cboss 09-20-2020 10:30 AM
Does your fresh water tank have water in it and is the valve from the tank in the correct position? The valve may be in the "winterize" position.
nomad297 09-20-2020 10:52 AM
When you say it stops, are you saying the pump stops or are you saying the pump continues to run, but the hissing stops? If the latter, I would agree with cboss that your diverter valve is in the winterization/antifreeze suction position. Flip the switch on the valve and see what happens.
Bruce
rgklever 09-20-2020 12:14 PM
Bruce
The water stops flowing. Where is this valve located?
cboss 09-20-2020 12:20 PM
Usually right near the input to pump. It will be on the water line from the tank.
rgklever 09-20-2020 12:59 PM
Thanks. I’ll check it out.
bikendan 09-20-2020 01:47 PM
It would help if you posted year and model number, since valve locations vary wildly between brands and models.
5picker 09-20-2020 02:08 PM
Also... do you have a ShowerMiser valve on your shower? It may be in the wrong position orcracked.
rgklever 09-20-2020 07:05 PM
Thanks everyone! The valve was on winterize. Appreciate the help!
